ABS light coming on after tire slippage.
masanders
36
Greenville, SC
2.5 (4 Cylinder)
2.5L
Don't get louder, improve your argument.
Why would the ABS light come on after losing traction? Example: it's raining here and I like to floor it from a stop to break traction. The ABS light comes on and doesn't reset until I turn engine off.
Is that its intended function?
Sent from my SM-G950U using Tapatalk
It sees the rear wheels moving and the front wheels not moving, or moving much slower, and assumes there is a sensor fault. If you pull the codes you will probably get signal missing codes for the two front wheels, or signal mismatch, since it sees the rear wheels going 30-40 MPH and the front wheels barely moving, and the G switch agrees that you are barely moving.
I'd say this is normal.
