FastEddy760
- Feb 2, 2009
- Reaction score
- 0
- Make / Model
- Ford
- Automatic
Hello All,
I mounted some full size Bronco beams (and a Dana 44) on the stock positioned Ranger mount points. 1997 Ranger Xtra Cab 4wd / 1994 Bronco Beams
I'm curious if anyone knows the answer(s) to the following:
- Is the mount points on a Ranger, the same distance as a full size Bronco?
- Will the Bronco axles fit from Dana to hubs?
- Do I need to cut and fab new mounts for the beams in order to use the stock Bronco axles?
The steering is not a concern at this point, as we can fab that up.
There is a bit of difficulty in testing the fitment as one of the axles disappeared and I need to find another. Otherwise we would be further along in mocking, measuring and visualizing.
