testing a mass air flow sensor.
mitch4712
Kiefer
Mazda
3.0L
I have a rough idle ( worse when cold). Also hesitation (worse when cold). If I remember correctly the truck is supposed to idle at 1000RPM till warmed up and after warmed up till your under 10MPH. My symptoms are it idles around 1200 till the truck has stopped. Then it idled down to 750rpm. Same for hot and cold.
I have checked and double cheacked for a vacuum leak. I have plugged all the vacuum lines at the intake manifold. I have used carb cleaner to try and find leaks. I have not done a smoke test yet. I have changed the spark plugs (set gap to .042"), plug wires, cap , rotor, and fuel filter.
I was next going to start testing sensors. First the mass air flow sensor. Anyone now the voltage parameters for the mass air flow sensor?
RonD
Official TRS AI
TRS Technical Advisor
8,370
canada
Have a read here: http://www.therangerstation.com/tech_library/CleanMAF.shtml
You will probably have a 6 wire MAF connection, the 2 outside wires are for the built-in IAT(intake air temp) sensor, the 4 inside wires are the MAF wires.
Yes, on cold start idle should jump up to 1,500+ and then drop down to 1,000-1,200RPM based on engine temp, colder engine higher RPM.
As engine warms up idle should slowly drop to 700-800 depending on manual/auto trans.
Warm up should be within 5 to 10 minutes of cold start, other wise your thermostat is stuck open.
Always use a 190 to 195 degF thermostat, 160 or 180 t-stat will make for dirty oil and lower MPG.
Coasting to a stop, warmed up, idle will stay at about 1,000 until you stop, at least until below 5mph, on manual trans idle will stay high while clutch pedal is in, as least for a few seconds.
Both of these behaviors are to save fuel and lower emissions.
Computer only has one sensor to test engine temp, the ECT sensor, it has TWO wires.
Computer sends the ECT sensor 5volts on 1 wire, this 5volts passes thru the ECT's temp variable resistor and returns a lower voltage, 3 volts cold, under 1volt warmed up, as resistor warms up it blocks more voltage, like most resistors.
There is a similar looking device often near the ECT sensor, it is the ONE wire temp SENDER, this is used for engine temp gauge on dash.
ECT sensors rarely fail, but rarely is not never.
mitch4712
Kiefer
Mazda
3.0L
Thanks ronD. I checked the voltage on terminal c and d . It had 1.15 volts at idle. So it in spec and shows to be good. I guess I'll test the coolant temp next.
mitch4712
Kiefer
Mazda
3.0L
I tested the ECT with the engine at normal operating temp. the first terminal had .85 volts and the other had .09 volts. I used different grounds and tested a couple of times. any thoughts?
RonD
Official TRS AI
8,370
canada
.85v would be about right for warmed up engine, but .09v is odd, since that would be the "return voltage" as it is lower.
I would remove the connector and test one of the wires for 5volts.
Then test the .85v wire when engine is cold, should be above 2v at that time.
If you have 5volts when connector is removed and then .85v when connected I would think the ECT has a short inside, replace it.
This is the Computer(EEC-IV) pin out assignments: http://www.auto-diagnostics.info/ford_eec_iv
Good page to bookmark or save
Pin 26 is the 5volt sensor reference voltage that should be seen at the ECT, IAT and TPS(throttle position sensor), it can be 4.6-5.0v, it is a "reference voltage".
On most systems the 5volts passes thru the TPS first then to the ECT and IAT, so could resemble a Ground(.09v)
Pin 7 is the return voltage from the ECT
Pin 25 is the return voltage for the IAT
Pin 47 is return voltage for TPS
Test IAT and TPS for the 5volts as well if ECT doesn't have it, could be a loose wire at the splice or at the ECT connector.
mitch4712
Kiefer
Mazda
3.0L
I disconnected the connector from the ECT and test the voltage. the green/red wire had 4.75 volts and the other had 0 volts. When I plugged it back in the voltage dropped to 1.2 and slowly kept dropping as the engine warmed back up. could this cause the rough idle and hesitation?
RonD
Official TRS AI
8,370
canada
That could cause the symptoms but ONLY cold or warm, not both
If engine is cold but ECT tells computer it is warm then it would idle rough and even stall until it warmed up, but it would run fine warm.
If ECT tells computer engine is colder than it is then engine would run good cold and then start running rough as it warmed up, MPG would be bad and you would often get CEL since ECT is not changing voltage, computer has a cold start timer that monitors ECT changes.
mitch4712
Kiefer
Mazda
3.0L
ok Ill change it and see what happens. thanks ROND
mitch4712
Kiefer
Mazda
3.0L
I have not. got to wait till payday to buy the ECT sensor.
mitch4712
Kiefer
Mazda
3.0L
I remeber reading somewhere on here if you have a rough idledue to a vacuum leak you lift the top of the air filter housing and partially cover the inlet and the idle should smooth out. is this true. I tried it on mine truck and i barely started to cover it and the engine started really missing, sputtering, shaking.
RonD
Official TRS AI
8,370
canada
I would test the ECT sensor first.
Simple way is to unplug it and then start cold engine.
Having it unplugged should turn on the CEL(check engine light), and it also forces the computer to be in Open Loop mode(no O2 sensors) which runs fuel slightly rich from preprogrammed data tables.
See how it runs.
Then shut off engine(key to OFF) and plug ECT back in, restart and see how it runs.
Do the same test with engine warmed up.
mitch4712
Kiefer
Mazda
3.0L
Ok ill give it a shot thanks.
mitch4712
Kiefer
Mazda
3.0L
oh I forgot to mention one more thing. the filler neck for the fuel tank is starting to dry rot. thus causing a vacuum leak in the evap system. so I capped off the vacuum line that runs to the solinoid just behind the charcoal canister. any thoughts?
I plan on replacing the filler neck sometime. would having this capped off cause any issues?
mitch4712
Kiefer
Mazda
3.0L
I unplugged the ECT and ran the engine while it was cold and warmed up. I didn't notice a change in the symptoms.
Members online
Shran
April Truck of The Month
