Trying to resurrect a new to me, butchered 302 conversion, need help ASAP !
84FreakRanger
Tifton, Ga
306
Should be easy answers for those experienced with 302/Ranger conversions.
Need help ASAP, trying to get this thing resurrected before I move out of State in less than 7 weeks
http://www.therangerstation.com/forums/showthread.php?t=167388
If you're still messing with the MAF sensor stuff and computer. I would get rid of all that junk and go Carb. It's less money and save money and time.
The headers go with Tri-Y with a small 157 teeth bell housing
The Rad go with http://www.ebay.com/itm/390648150682...:MEBIDX:IT
Northern 205138 Aluminum Radiator 82-94 Ford Ranger V8 Engine Conversion Swap
Trailrated92
2
Appreciate the tip, but Im committed and already to deep into the injection set up to turn back now.
Is the AOD trans a 157 tooth bell housing ? Link to Ebay says listing removed or item no longer available
84FreakRanger
Tifton, Ga
306
AOD TRANS are mostly 164 teeth. You can get shorties headers but don't get the heddman headers 89500 because the passenger side header has to be mod.
the rad is available, ebay is glitching, that is why I put the name a part # below the link so you cut and paste it on ebay or google to find it
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
Engine Type
V8
357w
2WD / 4WD
Solid Axle Swap 4x4
13ish
39.5x15.5
Get a drive shaft with the right ends, preferably longer than you need, and have it cut down, there are driveshaft shops in every city.
Staff online
Shran
April Truck of The Month
