cowboycowboy91
- Jul 21, 2015
- Reaction score
- 1
- Location
- Oklahoma
- Make / Model
- Ford
- Engine Size
- 3.0 L
- Automatic
I have a head scratcher...my 4x4 2000 ford ranger 3.0 ff vin V is missing like crazy. It has no knocking or pinging. This is the second engine I have put in this truck and both engines have displayed the same problem. I replaced the old engine due to a rod bearing spun. The new engine was low milaged. It ran smooth as silk when I first installed it, but 200 miles later, the same old problem came back. If I clear the codes, it is good for another 200 miles. The codes displayed reveal a misfire code and a camshaft position sensor code. It also had a wiring fault code for some circuit and O2 sensor codes (yeah, a mess I know). I compression checked bank 1 and 2 and it read as follows...Bank 1-90,120,90 Bank 2-120,120,120. The code scanner revealed that the misfires were occuring on the cylinders with lower compression. No suprise there. I assumed a head problem/valve prob. I didn't do a wet compression test or a cylinder leak down test, but I am pretty certain it is in the head. Now the puzzling thing...why in the world would clearing the codes make it run perfect for 200 miles? Also, I assume since this engine doesn't have variable valve timing or anything, then there is no timing issue that can cause this...other than a slipped timing chain...right? Could anything throw off valve timing enough to cause compression loss? I checked it running by the way. Anyways, just wondering why clearing the codes causes it to run perfect for a short time and if any electrical controled timing components exist to cause it to have delayed or advanced valve opening/closing. Sorry for the book long question, and thanks in advance for any responses.
