- Nov 27, 2008
- Reaction score
- 63
- Location
- central IL
- Make / Model
- ford
- Engine Type
- V8
- Engine Size
- 1975 302
- Automatic
- 2WD / 4WD
- 2WD
- Total Lift
- 6+3
- Tire Size
- 33/12.50/15
I have been having some problems with the steering being loose but I was thinking it was the pump.I started the truck to go home yesterday and the pump was whining, because it was empty I washed the pump and gear off at the car wash to find out where the leak was. It was running out of the top of the gear box were the adjustment screw was. I tried to tighten the lock nut up but it just kept turning and turning. I am guessing that it is trashed? If I have to replace it what other ones will fit? I am wondering about one from an f-150 of e-150. If not would it be better to get a junkyard one or a rebuilt one?I am going to replace the pump also just so it is all new. I read in the tech section about the upgrade for the pump,but they do not make them anymore so are the plastic replacements still an upgrade.I do remember reading about a gearbox upgrade but could not find it after searching. I think you had to grind a bit of the frame to get it to fit? Thanks for any help or info.
