Whats so bad about an auto transfer case?
Xandor
3
Bloomfield IN
2.9 2.9 2.3
I'm going to be puting a 89 body on a 88 frame, the 88 has a manual transfer the 89 has an auto. I like the free space on the floor and I'd rather swap the cases than cut a hole on my floor, but it seems everyone says the autos are junk. Why?
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
The more complicated that u make something , the more things that can go wrong.
The push button can fail, the shift motor can and will fail(probably when u need it most).
The wiring can go bad, and so on and so on.................
If u have a good workin auto t case, use it, but I'd hold on to the manual one JIC.
explorerhavok
3
Colorado
Ford Bronco
302
2WD / 4WD
Just to give you an idea out of the six RBV's I have owned 1 is all manual and that is the one I currently have. The other 5 had the electric shift transfer, of those 3 did not work and 1 quit while I had it, with all of them the issue was the shift motor. I would say the shift motor is the weakest link! Also you should not have to cut the floor, there should be a plate that can be taken off and with the plate for the manual shift.
ragajungle
Burlington, WI
2.9L V6
Xandor
3
Bloomfield IN
2.9 2.9 2.3
michowski
2
Mines been good for like 5+ years now with auto. Dont use it a lot but everytime I have its been just fine.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Auto is nice when it works, manual is nice because it always works.
I like my manual just because it's more fun to drive in the snow with the 4x4. The other nice thing about the manual cases is the available N setting in case you ever need to tow the truck.
88_Eddie
Solid Axle Swap
155
Raleigh, NC
2.9L, 4.0L
i have an 88, back in high school (about 11-12 years back) it always worked, never had a problem. as it started getting older, sometimes it would go in 4 wheel and sometimes not. my dad took off the shift motor and cleaned all the electrical connections one day, and then it worked for a few years with no problems. this past year, we got about 10 inches of snow and it would go in 4H, but not 4L. it was ok tho, cause i didnt really need the 4L for the snow.
that being said, i just bought a manual 1350 from another TRS member for $100 so i dont have to deal with it not working anymore. and one more thing, a shift motor for these cases is ~$100 depending on where you go (and it'll eventually go bad again too)
go with the manual
Original_Ranger84
TRS Banner 2012-2015
20
Homer, Ak/ Anchorage, AK/Fairbanks, AK
2.8L, 3.0L
All in all the Auto transfer case and manual transfer case do the same thing but the manual has a stick on he floor and when you pull it it goes into 4x4. The auto you push the button or turn the knob then it sends a signal to the 4x4 computer then that senses if the parameters meet up for what you are asking it to do (Is the clutch in or in neutral, parking brake on, vehicle moving... ect) then it tells the t case to shift.
I like the manual t cases and actually just picked one up to install in my 99 cause they didn't come with anything but. I like reaching down and physically feeling that i put it in 4wd... Turning a stupid knob is so unsatisfying and half the time i can't tell if it went in or is still waiting...
Doofy
7
Alaska
3.0
Shit Happens...Then You Die.
If it ain't broke, don't fix it! My ranger is 12 years old and never had any problems with the auto transfer case. If it chooses to act up...then it will get repaired.
84bluebronco2
13
Central New York
4.0
My auto t-case works, but the whole back up to deactivate is what makes me want to put the 1350 my Explorer. Did the 84 B2 come with a 1350 and if so is it bolt in swap (minus shift linkage) with 1354 from my Explorer?
AllanD
TRS Technical Staff
TRS Technical Advisor
134
East-Central Pennsylvania
1987... sorta
'93 4.0
The "extra space" on the floor is more of an illuson than reality.
The electric shift system fails for more than the reason stated above, a steel lever MUST work..
As for cutting a hole in the floor? Ahhh... No.
there is a removeable floor plate that you get to unbolt.
AD
LittleHorse
Pryor, OK
2.9L
the backing up to deactivate is for the hubs, not the t-case.
You're welcome to put the manual 1350 into your explorer but you'll still have to back up to unlock the hubs.
(if you need a set of manual hubs and the conversion kit, I've got them listed in the classified section)
As for the swap - the front driveshaft on the 1350 is a slip yoke and the 1354 is a fixed yoke on the transfer case end, so you'd need the front driveshaft with the 1350. There may be other complications with the linkage depending on your transmission but I don't know, my BII came with an auto 1354 and I swapped in a manual 1354.
The_Dealer
10
Macon, GA
Duh!
auto never works, follow the K.I.S.S method (keep it simple stupid), that way it works when u need it
i have a 1350 t-case for sale if u need one
Members online
No members online now.
Shran
April Truck of The Month
