wondering what this gear ratio is
Harley
2
Oregon
Ford bronco 2
Engine Type
2.9 V6
2.9
2WD / 4WD
5.5 in susp 2 in body
the ratio ends in a 4.....any ideas?
Mac
183
C. Wisconsin
2000
199
4.0
What car/truck? Looks like a 4.15 to me but totally unfamiliar with that design, sure no a common one to me.
Dave
Harley
2
Oregon
Ford bronco 2
Engine Type
2.9 V6
2.9
2WD / 4WD
It was a 7.5 out of a ranger
Harley
2
Oregon
Ford bronco 2
Engine Type
2.9 V6
2.9
2WD / 4WD
I didn't see any ratios that ended in 4??
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I am not convinced that is the right tag.
alwaysFlOoReD
Forum Staff Member
TRS Banner 2012-2015
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
The tags I have seen have the ratio beside the nut, not out in the middle. Also, I don't see any numbers ending in four. I do see a number beginning with four.
Richard
Harley
2
Oregon
Ford bronco 2
Engine Type
2.9 V6
2.9
2WD / 4WD
Weird huh...that was the diff tag...you can see the 7.5 on it...
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Are you sure that tag doesn't say 75-140? As in the gear oil spec?
Harley
2
Oregon
Ford bronco 2
Engine Type
2.9 V6
2.9
2WD / 4WD
Not sure...lol...that's why I'm asking, was looking for a rear with 4.10 gears
4x4junkie
Forum Staff Member
583
So. Calif (SFV)
Bronco II
Engine Type
2.9 V6
2.9L V6
2WD / 4WD
35x12.50R15
I seem to recall having seen two tags on some axles... Is there another tag on it maybe?
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Lots of axles have two tags. One IDs the axle, gives the gear ratio, and has what I believe to be a serial number. The other generally specifies the type of lubricant to be used.
rawrrediffer86
Illinois
4.0
Look on your door there is an axle code. Like mine is r6 which is the 8.8 with 3.73 limited slip. As a f6 is the 7.5 with 3.73 limited slip.
Sent from my SCH-I545 using Tapatalk
Harley
2
Oregon
Ford bronco 2
Engine Type
2.9 V6
2.9
2WD / 4WD
It was at a junkyard. It did not have a door
rawrrediffer86
Illinois
4.0
Oh that makes sense. Was just trying to help.
Harley
2
Oregon
Ford bronco 2
Engine Type
2.9 V6
2.9
2WD / 4WD
I know...thanks.....was looking for a 410 rear
Staff online
Members online
Today's birthdays
Shran
April Truck of The Month
