A bit torn. Do body work now or wait?
jhammel85
Guest
So my truck needs body work done and I have just about everything I need to do it except for doors and a fender.
My worry is if i should basically piece meal the body work and do a little at a time over the winter or if i should wait and do body near the end of winter and paint in the spring.
My fear is that my truck is a daily driver and snow (salt) is always a problem. I dont want to do all this body work and prime it only to have it rust over the winter. Now i understand that the primer might seal and ill have to do the usual prep work before I paint in the spring regardless, it still worries me that I'll end up with a bad paint job if i dont do everything at once.
What do you think? Im itching to get out there and start welding!
RonD
Official TRS AI
TRS Technical Advisor
8,290
canada
I would do the body work now and prime it.
Reason being you may find other things that need tending to while doing this, which would mean more of a delay if you waited.
And any rust over the winter on repaired areas will just be surface rust and easily dealt with before final paint
jhammel85
Guest
I thought the same about the rust. Rust does creep though, you know? If I'm totally honest, i have cold feet. I shouldnt but I do.
Hmm, i should start a build on here.. Thanks again RonD
dirtcowboy
Solid Axle Swap
5
NW Montana
FORD
2.9, 4.6, 4.0, 6.8, 5.0x4
do the body work now, then use epoxy sealer. No rust. Primer absorbs water, could rust.
97RangerXLT
Forum Staff Member
3,841
Fishers, IN
Engine Type
4.0
2WD / 4WD
2"
31"
Yep, and try to seal the backside of the metal too if you can...
AJ
jhammel85
Guest
Will do. Thanks for the tips, all. I'm trying to save myself from headaches down the road. Outside of the typical dings and dents, I have rusty wheel wells to address (new panels are in my garage), Door Jamb rust, passenger side fender rust and a few pin holes here and there that need to be filled in. Overall, I've seen and dealt with worse but we'll see what happens when I get into it...
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,489
SW Iowa
Engine Type
V8
5.0
How are you dealing with the door jambs?
I haven't been able to find the pieces I need to fix mine.
jhammel85
Guest
Mine is rotted out as shown, except it has a hole all the way through now. uploadfromtaptalk1408374472702.jpg
Luckily an awesome member on here had what i needed and chopped it out.
Its probably the only way to go unless you wanted to use metal mesh and bondo... Thats something the idiots before have all over my truck. Im making a build thread now so if you swing by sometime in the near future, you'll see the boulder of bondo coming out of my rear fenders. Literally a few inches thick..I'm doing my best to avoid bondo unless I'm skimming.
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,489
SW Iowa
Engine Type
V8
5.0
Yup, that is exactly what mine needs (not that bad though)
I wish LMC or somebody would get on the ball and make that piece. EVERY Ranger I have looked at in the JY is the same if not worse than mine so it must be pretty common.
ab_slack
TRS Banner 2012-2015
12
New Joisey
2.9L
Thanks for posting the question. Mine is in pretty good shape but last winter really beat up the paint around the fender wells bad and some serious surface rust has started to show.
Want to get at least those areas before they get any worse and protect up some others. Just not sure how to go about it really.
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,489
SW Iowa
Engine Type
V8
5.0
I would like to coat the lower rockers with bedliner to give the gravel something to play with besides paint. The real stuff not the rattlcan crap.
Dunno if I am going black or tan yet though...
jhammel85
Guest
Yeah, there are quite a few body parts they dont have. As they gwt older, hopefully they'll start offering them.
Hell, im looking for the tailgate bushings on LMC right now. No dice.. They have them for third gens though so i suppose theres hope.
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,489
SW Iowa
Engine Type
V8
5.0
I don't know if first gens have bushings, I remember running into that when I picked up a different tailgate.
jhammel85
Guest
Oh really? Damn, well that might be why, lol. Mine rattles like crazy. It needs to be adjusted too.
I hope to find a decent tailgate around here soon. I dont really care fof the ss ford lettered panel i have on mine now. I wany a stamped ford tailgate. They just look perfect on a 1st gen.
jhammel85
Guest
I welded in my fenders and all seems well. I need to do a bit more of the detailed work like wet sanding it and all and i need to sand down an imperfection or two.
So if i shoot it with epoxy primer sealer, am i able to sand that down in a few months and do the wetsanding then? I just want to keep all of this sealed from the weather till then. I'd also hate to seal it and then wet sand it down, and then reseal it back up again if that causes problems. Im just too timid to let it stay primed all winter. I dont know enough about sealers...
Thanks again for everyones help.
Staff online
Kirby N.
March Truck of The Month
