where is orifice tube
croatankid
5
jacksonville, nc
ford
4 liter
I'll do it myself
in my 90 ranger 4 liter? i'm updating my ac, changing the lines from the compressor, the canister thing and the orifice tube. I can't find it.
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
Let me help you with some terminology.
The thing Inside the Box on the firewall is called an evaporator, the canister is an accumulator drier, the lines to the compressor and condenser are called refrigerant lines,
what looks like Radiator in front of the radiator, is a air conditioning condenser.
The orifice tube is named improperly.
it's an orifice that fits inside of a tube.
The refrigerant line coming from the condenser leads to the evaporator. when you first look at it you think it goes into the bottom of the accumulator but it doesn't. The orifice fits in the tube at the bottom of the evaporator. This is where the orifice will be, you'll need needle nose or a special tool to pull it out. they are plastic and hard to get out because they get driven into the tube from the high-pressure refrigerant. You will most likely replace it with a blue orifice.
While you are doing all this, you want to make certain that your fan clutch, fan, radiator and condenser are in top condition. if you don't HEAR the fan when it's hot out, it means a fan clutch may not be working right and your air conditioning will not cool properly.
croatankid
5
jacksonville, nc
ford
4 liter
I'll do it myself
orifice
thanks for the answers. I was about to go look into the exit line of the evaporator since I hadn't seen it anywhere else. It's going to be hard to get to since it's under the battery box and other things. But now I know where it is. Again, thank you.
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
The orifice is actually a refrigerant metering device, they are always on the line going into the evaporator, not out.
What model truck / size engine do you have? battery on the right?
My 4. 0 is on the right, meaning passenger side, and the air box has to be removed
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
One more thing about the orifice, it's real easy to look at it and think it's backwards. the flow is towards the evap, coil
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Orifice tube is always at the last access fitting going into the evaporator. The accumulator is always on the outgoing side of the evaporator, makes it easy to figure out which side is which.
Also, if you look around closely at the lines near the evap you can often find small crimp marks in the line, looks like someone pinched it with some pliers, that is where the orifice is.
croatankid
5
jacksonville, nc
ford
4 liter
I'll do it myself
I found it at the last fitting leading into the evaporator box. It was pretty hard to pull out but I did get it out. It was covered with sludge. No, it wasn't inside the box but almost directly under the accumulator.
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
Just wondering did you even read or look at the information that we gave you? good luck
croatankid
5
jacksonville, nc
ford
4 liter
I'll do it myself
I removed and replaced the orifice. It is located in the last fitting leading into the evaporator box almost directly under the accumulator. It was covered with sludge. Now I have two questions. My mechanic told me to drain the compressor and replace the oil with oil having die in it. He showed a plastic bottle of what he uses. I can't remember what type it is, what number, i.e., 100 or 150. was it peg or ether? I went to the parts store but didn't find what he had. What oil should I use, with die in it. The next question is about a vacuum line at the evaporator box. There's a canister mounted on top of the evaporator. Next the firewall there is a vacuum line coming out of the canister. It leads to a T.. From there one 1/8" line is blanked off. Another, bigger line goes back to the vacuum manifold. Where should the blanked off line go?
croatankid
5
jacksonville, nc
ford
4 liter
I'll do it myself
what are you talking about. I said I found the orifice. I appreciate your help.
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
It seemed like you hadn't read any of the advice, no matter.
Good luck
croatankid
5
jacksonville, nc
ford
4 liter
I'll do it myself
Your advice is what enabled me to find it. Thank you! Are you going to help we with my new questions?
4x4junkie
Forum Staff Member
580
So. Calif (SFV)
Bronco II
Engine Type
2.9 V6
2.9L V6
2WD / 4WD
35x12.50R15
Are you using a new (or remanufactured) A/C compressor? Or are you still using the original compressor that originally had R-12 in it? (this matters for which oil you need)
The canister above the evap box is a vacuum reservoir for the recirculated air vent door solenoid (operates when you switch between "A/C" & "Max A/C"). Hose from canister goes into a "T"... From there, one side goes to the vacuum manifold on the intake as you mention, the other side enters into a wiring harness (right where the wiring for the blower motor resistor comes out) and (I assume) from there goes to a valve or switch operated by the "Max A/C" control, and then finally to the fresh/recirculated vent door solenoid.
croatankid
5
jacksonville, nc
ford
4 liter
I'll do it myself
Thanks for the answers. I'm using the stock compressor. I intent to take it off and drain it and put some oil back in. I bought some Pag100 with die. I'll measure how much drains out and replace that amount or 3 ozs.
Members online
Kirby N.
March Truck of The Month
