aaaawwwwooooga horn?
spdcrazy
2
Homer, alaska
mostly 86
B2
2.9 bored and cammed
i've got an old awooga horn hooked up to my b2. but it spools up real quick. and i'd like to slow it down a bit, more like an old firetrucks horn. how can i go about this? maybe a certain resistor or something?
martin
26
St Bruno, Quebec
1991
ford
Don't know really but you might try using a blower motor resistor in line and see if that works.
mp3deviant721
24
Eau Claire, WI
2.3l of fury
Depends on how it operates. How does it operate?
spdcrazy
2
Homer, alaska
mostly 86
B2
self grounding. 14G hot wire from the battery, inline fuse, push button switch
mp3deviant721
24
Eau Claire, WI
2.3l of fury
I really couldn't tell you how slow it down. A resistor will probably only limit how loud it is.
spdcrazy
2
Homer, alaska
mostly 86
B2
hmm. never thought about that factor.
i'm completely clueless. hopefully someone has an idea? i don't even know where else to go on the interweb to ask?!?!?!?!?!:icon_confused:
LIMA BEAN
TRS Banner 2012-2015
140
ALASKA
2WD / 4WD
Most horns have an adjustment screw on them, maby a screw and lock-nut.
spdcrazy
2
Homer, alaska
mostly 86
B2
what does this adjustment screw adjust?
this is an original horn from the 30's, fyi. didn't see any screws for adjustment when i cleaned it up, but i wasn't looking for one then either..
Tony Raine
Solid Axle Swap
17
Jonesboro, AR
302
if its from the 30's, it may be from a 6 volt system instead of 12. i know there are fancy little things for making 6v gauges work in a 12v car, not sure what they are called though
spdcrazy
2
Homer, alaska
mostly 86
B2
i have thought about this before, but i don't know what a 6v horn would do on a 12v system. and this one works just fine. i don't have a 6v battery to test the horn on either.
schmoo
83 2.8 ranger
84 2.3 4x4 rang
they have a motor in them, so a resistor will slow it down.
i would try an old dimmer for dash lights. adjust it and measure
with an ohm meter. it will take less power that way too.
spdcrazy
2
Homer, alaska
mostly 86
B2
i wonder if i could use a dimmer switch, mount it to the fender well and have it adjustable?! not that having it adjustable is a very useful tool, but would be kinda cool
martin
26
St Bruno, Quebec
1991
ford
I would think it would pull a fair amount of juice, that's why I suggested a ballast resister for heater blower. A smaller resister will probably melt.
CSyd77
Delavan, IL
2.9 V6/3.0 V6
Try looking for a potentiometer. Its pretty much like a dimmer switch
Staff online
Shran
April Truck of The Month
