gpmiller78
- Oct 2, 2016
- Reaction score
- 0
- Location
- Dillsburg, PA
- 2000 body, fram
- Make / Model
- Ford
- Engine Size
- 4.0sohc
- Manual
Guys,
I need help. I just picked up a 2000 ford ranger ext cab xlt. it has the 4.0 with automatic. Got it cheap due to supposedly had bad motor. Put a new battery in and the thing went hay wire. Horn came on along with abs pump, cruise control relay, and parking lights. Also if you turn the key to on the wipers go on with the washer fluid pump. The crazy part is I disconnected the PCM and it still does it.
Thank you
Thank you
