shr3dd3r 09
- Feb 24, 2011
- Reaction score
- 1
- Location
- Huntsville, AL
- Make / Model
- Ford
- Engine Size
- 3.9L Inline 4 Cylinder Cummins 4BT
- Manual
- 2WD / 4WD
- 4WD
- Total Lift
- 3 Inches
- Tire Size
- 33X11.5X16 (285/75R16)
Okay so I have a 2000 Ranger with a 5.0 out of a 2000 Mountaineer. It's been sitting for a couple of years, and I recently started doing some restoration. Once I got it mostly put back together and hooked all the wiring up it fired right up and I let it run for a while. I've done this a few times over the last few weeks as I've been working on it and it has started right up every time until now.
Now all of a sudden it won't start. I'm not hearing the fuel pump with the ignition on, and all it will do is crank. I'm getting a 1:6 pattern from the theft light with the ignition on. It flashes rapidly with the key on for a while, then flashes 6 times...pauses...flashes 6 times...and so on. From what I understand this means a "faulty link between PATS and EECV."
So I don't know what I did to cause this. The entire PATS system and keys were swapped from the Mountaineer three years ago. Maybe I jostled something around while working on it and jostling the wiring harness. Amy ideas what the problem might be? Does anyone know what wires go from the PCM to the PATS system?
Just some info about the truck for reference:
2000 Ranger with 2000 Mountaineer 5.0 and wiring harness
M5ODR2 & BW4406
SCT chip (delete auto trans functions, EGR)
M5ODR2 & BW4406
