I don't have a picture.....
Main light switch
Looking at connector, one side has two pins, the opposite side has three pins.
I will tell wire colors from top to bottom.
3 pin side:
top pin (#1) is empty
middle pin (#5) is TN/WH (hot at all times)
bottom is LB/RD (#9) (courtesy lamps)
next column of 3 pins:
top is (#4) RD/YE (power in Start or Run)
middle (#8) OG/BK (4WD Indicator)
bottom (#11) empty
next column of 3 pins, which is next to the column with only two pins:
top is (#3) WH/BK (Parking Lamps)
middle is (#7) BK (Ground)
bottom is empty
Last column has two pins:
Top (#2) is RD/YE (Headlamps)
Bottom (#6) is DB/OG (Hot at all times)
This is from the 2000 EVTM. I have no clue whether all those colors will match your year, but the function of each wire should be the same. They haven’t changed that switch in many years.
