88 Ranger Swap Tranny Trashed Need Help!
Diggerauditor
South Bend, IN
5.0
OK, I did my engine swap, 302 and M5R2 last spring. Been driving it this winter with a few bugs to be worked on, mainly carburetion. My tranny went out in a grinding flash last night just as I got home. Started it up this morning and it was worse than expected. In short, I need another trans. I used a 01 f150 V-6 M5R2, as shown in my build. I didn't have a speedo cable because I had to take what I could get in a trans to get on the road again.
Does anyone know if all the R2s are the same physically. I know I can use a 97-98 since they still had the speedo cable in the extension housing. Will earlier models work? Which years will bolt to the 302? The reason I ask is that I can't find a 97-98 around here at all and it's cheaper to buy a good used trans than rebuild this one. Any help would be appreciated!
Thank you
win
12
5.0
Check out car-part.com, they're showing a number of the boxes available in Indiana
baddis
Solid Axle Swap
6
Avon,il
2014
4.0 Sohc 1.5 ecoboost
the top cover is different. the older ones I believe have the shifter in a different spot but you can swap the top cover fairly easy
baddis
Solid Axle Swap
6
Avon,il
2014
To bad you aren't closer I have a m5od r2 in my garage out of a 89 or 90 f150 with a 4.9. I think it needs a shift fork
Twister
17
Omaha, Ne
Duh
5.0L, 2.9L
The top covers have different shift forks, you would have to grind down the v6 top cover to fit it on the v8 tranny.
Sent from my SPH-L900 using Tapatalk
Diggerauditor
South Bend, IN
5.0
Awesome guys ty. I checked the site and there were alot in Indiana and some even had hardly any miles on them. Going to check that out. Prob pick one up next weekend.
Fant
U have to use a tranny frm a 4.2,4.9,5.0. The 4.6 has different bolt pattern on trans bell housing. All 5 speeds up to 96 ul have to change ur upper plate frm the trans u got. Its a direct swap. 97-03 are the ideal trans. As for speedo. Alot of transfer cases have speedo in them. I run np208 frm ford bronco. Speedo cable bolts in just like stock bw1350.
Diggerauditor
South Bend, IN
5.0
I found a 97 out of a 4.2 f-150 2wd using car-part.com just south of Indy. Picking it up tomorrow. Only has 20k miles on it.
Staff online
Today's birthdays
Shran
April Truck of The Month
