12.34MPG with 4.0
1989Bii
Lexington, NC
4.0
Does that sound about right with 33's and a 4.0?
4.0B2
TRS Banner 2012-2015
151
Walls, MS
4.0 v6
what gear ratio? auto or manual? is it running good and smooth? right psi of fuel?
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Gears? Kind of driving? I've gotten significantly worse than that (9.5MPG) and better (15+MPG), depending on where and how I'm driving.
kunar
Forum Staff Member
131
Toledo, Ohio
Engine Type
V8
5.8l
2WD / 4WD
2WD
have you corrected your odometer after the tire change?
1989Bii
Lexington, NC
4.0
Its a stock dana 28 from 89 so i guess it would be 410's. The transmission is auto and i'm driving it 55 miles exactly on the highway. I measured the distance using another car, my trip is still wrong cause of the 33's.
4.0B2
151
Walls, MS
4.0 v6
if your trip is wrong, its hard to calculate exact mileage. unless you do NOTHING but 55 miles a day....
1989Bii
Lexington, NC
4.0
What i did was, i filled it up before i left. I drove 55 miles EXACTLY, then filled the tank back up and divided the miles by the amount of gas i used and then i got 12.34. 12.34 is what it is getting highway, all im asking is if this is normal or should i be getting more?
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Auto combined with 4.10s isn't enough gear, you need 4.56s.
1989Bii
Lexington, NC
4.0
What are you getting with the 4.56s highway?
4.0B2
151
Walls, MS
4.0 v6
talked to a guy getting 16.5 or so with 33's and 4.56's with the a4ld..
if i can pull that off i'll be happy lol
edit: his 33's are bfg at's.. btw
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Like 14, but I do 70+ and I'm turning heavy and aggressive super swampers.
1989Bii
Lexington, NC
4.0
well i guess i'll need to save up for some gears. Thanks for the input btw!:headbang:
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I would like to point out that we don't KNOW that he has 4.10s. 3.45 was a much more common ratio that year.
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
I agree, I was thinkin 3.73's. That's what my 90's have.
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Has nothing to do with year, if it was a factory auto, it should either be 3.73s or 4.10s, and it's a moot point, because it still needs 4.56s gears, which we know it doesn't have.
Members online
Today's birthdays
Shran
April Truck of The Month
