HELP! Hazards/Blinkers Stopped Working on '99 Ranger
jkiefn1
Hello all. First let me say a huge thanks to all of you. I've been a quiet viewer of this forum for years now and many of you all's insight has helped me through troubling times with my truck.
Now for the question at hand, I will keep it short, sweet, and simple. I sincerely apologize if this is a stupid question, but I am already beyond my novice knowledge level.
My blinkers and hazards randomly stopped working on my '99 Ford Ranger, 2-door, 2WD truck.
I do not believe it to be the multi-function switch on my steering column due to the fact that my wipers, washers, brights, etc all still work.
I gave a visual inspection of the fuses, they seemed fine. But for good measure replaced the fuse in question with a brand new one-still not working.
I believe it to be an issue with my flasher relay, but would that cause an issue with both my blinkers AND my hazards? If so, could anyone post a picture or lead me to where these are actually located? I'm having a hard time locating them and don't want to go just pulling on important looking pieces of wiring.
Thanks in advance!
Joe
Skirbykat
Relay should effect both. Located under instrument panel, right of steering column, according to Haynes manual. I tried to get you a picture, but kinda hard to see. Hope it helps.
Staff online
Shran
April Truck of The Month
