tab a
- Oct 22, 2016
- Reaction score
- 0
- Automatic
Tried to run this on my 97 3L automatic. CC flashes when ign turned on, and again, when CC 'on' pushed, as it should. No flashes after that for RSM, CST, etc.
Am doing the test because I've found that when the CC wiring harness is attached to the module my speedo doesn't work, and vice-versa. Thread about that nightmare is here:
www.therangerstation.com/forums/newthread.php?do=newthread&f=54
Was trying to prove that my CC module is OK, though I still suspect this is a wiring problem. These symptoms bring anything to mind?
Will also post this info in that VSS thread.
Thanks.
Thanks.
