Oil Level Sensor (Relay)
Mazda
11
Temecula, CA
Mazda
2.3
1994 Mazda B2300
Been getting a "Oil Level" warning for the past couple of weeks and I know the oil is full. Just did a oil change.
Everything I have seen on this says you need to check the sensor and the "timer relay" but nowhere does it say where this relay is?.
Anyone know?
The sensor is only $20.00 and is most likely the problem but would like to be sure and test the relay also.
hondaxr650
4
Tacoma, WA
Never had to replace the relay but the '94 Ranger wiring diagram shows that relay is behind the instrument cluster.
Mazda
11
Temecula, CA
Mazda
2.3
Thanks,
I think I will just buy a new relay then to. I can only find them a dealer ($45) or E-Bay ($20). Don't want to have to pull the whole thing apart to test and find out is bad and put it all back together waiting for the part. The only test I could do was disconnecting the lead to the sensor and the light stayed on so that indicates a problem with the relay.
