Hsmcorey
- Aug 12, 2012
- Reaction score
- 0
- Make / Model
- Ford
I just put a carbureted 302 in my 95 ranger, everything works great except the starter wont engage using the key. If I jump the solenoid on the inner fender the truck starts right up but Im not getting power there from the standard lead. I did have the neutral safety switch off several times while bleeding the clutch (that really should be easier than it is) but I verified 3 times it was re-installed properly. Since I have disconnected the EFI harness is there something that needs to be plugged in to make the neutral safety switch operate? I haven't found a wiring diagram that shows where all of the wires on that switch go but I'm sure several go to the ECU and I'm guessing the ECU is missing an input from somewhere that allows the starter to work but I just don't know which one. I have spent over an hour now using the search bar trying to find someone that had a similar problem with no luck yet. Im on a very short deadline to get this truck back on the road and this and running the exhaust are about the only problem I have left to solve and Im hoping to not have to just put a push button start switch in.
Thanks for any help you can offer.
Corey
Corey
