Can I swap a metal upper intake manifold for my plastic?
cp2295
7
Washougal, wa
4.0L swap, 8.8 explorer axle, IFS front end
If you ain't first you're last
I have a 98 4.0, with egr, can I swap it out for the metal one? I figure I can find a ranger or explorer with egr with a metal manifold and just take the egr piping. Looks like everything that needs to bolt on, will.
holyford86
Some guy with a problem
RBV's on Boost
GMRS Radio License
610
Plattsburgh, NY
many
4.0
2WD / 4WD
33x12.50R15
AgPete139
09/2014 OTOTM Winner
OTOTM Winner
Solid Axle Swap
TRS Banner 2012-2015
61
Houston, TX
Engine Type
4.0L OHV
2WD / 4WD
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
What are the benefits of swapping the metal intake?
cp2295
7
Washougal, wa
You can port it and it won't crack like those plastic ones
AgPete139
OTOTM Winner
Solid Axle Swap
61
Houston, TX
Engine Type
4.0L OHV
2WD / 4WD
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
Ah. I see.
You're porting and polishing your 4.0? All the ones I've seen are plastic. What models come with metal?
holyford86
RBV's on Boost
GMRS Radio License
610
Plattsburgh, NY
many
4.0
2WD / 4WD
33x12.50R15
All of them 90-94 were aluminum, cali emissions 93-94 had egr.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Rangers started getting plastic intakes in 93. The Explorer kept the aluminum one through 94.
Napabandit
2
Napa, CA
4.0
My 93 has an aluminum intake. I have replaced several of the plastic ones that developed vacuum leaks.
cp2295
7
Washougal, wa
I'm gonna get an aluminum one for sure
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
OTOTM Winner
Solid Axle Swap
372
Nevada
Engine Type
V8
5.0,4.0
2WD / 4WD
Solid Axle Swap 4x4
6”
I just ordered one from ebay. I'm gonna be installing it in two weeks. My plastic one is leaking between the upper and lower.
I paid $55 with free shipping for a 94 explorer alum intake with a egr.
AgPete139
OTOTM Winner
Solid Axle Swap
61
Houston, TX
Engine Type
4.0L OHV
2WD / 4WD
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
That's a good deal. I tried looking for the same thing, for giigles. Many have no EGR, or the price comes out to $75 for n EGR mani after shipping & handling.
PlumCrazy
OTOTM Winner
Solid Axle Swap
RBV's on Boost
2014 Truck of The Year
168
Millersport, OH
Engine Type
V8
2WD / 4WD
Solid Axle Swap 4x4
Ranger plastic started in 95..with the ODB II system.
The plastic is already smoother inside and doesn't not heat soak like the aluminum...going back to aluminum is a downgrade.
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
My 94 ranger (HWW) has an aluminum, I'll be swapping mine out for the M90 aluminum, so mine will be up for sale shortly after...
SVT
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
OTOTM Winner
Solid Axle Swap
372
Nevada
Engine Type
V8
5.0,4.0
2WD / 4WD
Solid Axle Swap 4x4
6”
Mine separated at the seam on the top of the plenum and it's leaking at the base at 1,4 cylinders.
Staff online
Today's birthdays
Shran
April Truck of The Month
