brett387
- Dec 27, 2014
- Reaction score
- 0
- Location
- Florida
- Make / Model
- ford ranger
- Engine Type
- 2.8 V6
- Manual
- 2WD / 4WD
- 4WD
- Total Lift
- 3 inch body lift
I tuned the carb to the best of my ability, which isnt very good. I can get it running no problem, but when i go to press the throttle while idling, its sticky and not easy without a spike in rpms after i press it harder. But after i hit the gas, the throttle moves fine. Is there a way i can adjust it to get smoother throttle movement. Also any tips and tricks on tuning it better and adjusting the choke if it needs to be adjusted? Thank you!
