Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Engine & Transmission Forums > 4-bangers > 4-Cylinder (2000 & Older)
Notices
Reply
Thread Tools Display Modes
Old 05-17-2018, 10:58 AM   #1
Tag1260
Tag1260 is on a distinguished road
Default 1995 2.3l Crank pulley removal
OK. Need to get the crankshaft pulley removed from my engine. Got the bolt out no problem. CANNOT get the pulley to budge. Any ideas? No holes for a harmonic balancer puller. Not sure I can get a gear puller on it. HELP!!!!!!
Thanks
Tag1260 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Rock Auto Discount Code: 20B2FF503DCF74 Expires: September 28, 2018
Old 05-19-2018, 10:07 AM   #2
scotts90ranger
scotts90ranger's Avatar
Vehicle Year: 1990
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: holding down the driveway
scotts90ranger is a jewel in the roughscotts90ranger is a jewel in the roughscotts90ranger is a jewel in the rough
Default
What year? There's at least 3 different pulleys... I only have experience with the mid 80's and the early DIS version. Usually they come off without too much effort, I don't think I've had to use a puller as they aren't pressed on. I think a dead blow hammer hit (or a normal hammer with a 2x4 between the balancer and the hammer) around the perimeter could knock it loose. It might help to take the pulley part of the assembly off if it is removable
Just saw the '95 in the title, that might be the type with the tone ring right behind the pulley and the crank sensor off to the passenger side front of the engine... I believe the pulley part comes off most likely with 4 bolts from the front like the older ones, still same method from above, pretty sure that's what I've done...
__________________
converted to 4x4, turbo'd the 2.3, 6" lift with 35's and 5.13 gears!
Send e-mail instead of PM, box full...
scotts90ranger is offline   Reply With Quote
Old 05-19-2018, 10:11 AM   #3
Tag1260
Default
Thanks for the reply.
1995. I had to use a puller but it didn't take much. However I did find the problem. The crank sprocket had spun on the crankshaft and the key was bent. Now I either have to replace the crank or try a repair/patch that I read about. Probably try the patch as with 230,000 miles a full rebuild would make more sense with a new crank. Now I have to start looking for a donor engine.........
Old 07-12-2018, 06:19 PM   #4
Dav
Junior Member
Vehicle Year: 1995
Vehicle Make: Ford
Vehicle Model: Rangerxlt
Dav will become famous soon enoughDav will become famous soon enough
Default
have mine apart again for the same thing but... turns out the balancer, which spun about 3 years ago, didn't spin again. last time, it sheared the key and broke a chunk off the keyway on the crank. put in a new key-about $3 from ford!- and put it back together.
not sure yet what the problem is. but with over 300k on the motor, i'm just looking to keep it running for another year
Dav is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
94 ranger 2.3, 4 bolt crank pulley removed, crank snout blocking timing belt Nisif Need Urgent Help Fast! 16 12-08-2015 03:41 PM
crank pulley removal help azureruza 4-Cylinder (2000 & Older) 3 01-07-2010 09:57 AM
Need crank pulley dngr_rngr94 4-Cylinder (2000 & Older) 3 05-31-2009 01:05 AM
Crank pulley removal question MentalJunkyard 4-Cylinder (2000 & Older) 4 07-29-2008 05:03 PM
crank pulley hub ejholmgren 4-Cylinder (2000 & Older) 4 06-02-2008 11:22 PM
© 1999-2018 / 959 Media LLC / All Rights Reserved
