Patrick
- Aug 23, 2016
- Reaction score
- 0
- Make / Model
- Mazda
- Automatic
So I got an intermittent CEL a few weeks back. The stored code was 332 for insufficient flow through the EGR valve. So I decided to replace everything EGR... The dpfe sensor, the actuator thing, and the valve itself. Now the light comes on whenever I drive at a constant speed (say, 30 mph). Same code 332.
Any clue what is going on? I replaced the sensor with the motorcraft retrofit one where you solder the new connector in. Seems that after the sensor was replaced was when the light came on all the time.
Could it be that the new sensor is reading more correct than the old one, and a mechanical problem is amplified?
Sent from my Nexus 6P using Tapatalk
