Josh40601's Build Thread. (D-ranged)
Josh40601
OTOTM Winner
MTOTM Winner
Solid Axle Swap
12
San Diego
Well, decided to update the 1st post with what the Ranger has evolved into. When i bought it, it was May 2008. It was bone stock and i bought it from the original owner. It had around 120k on the ticker, and for being 14 years old, that was pretty good. The truck was in great shape, other than it needing a throwout bearing. I never took pictures from when it didn't have aftermarket wheels, but it had 15"
Here is my 94 supercab XLT. I am the second owner of this truck and all the work was done by me. Now that i have a newborn and am a fulltime student, i cant keep working on it, so i have to pay people to do it. The work it has now is a Dana 44TTB, 9" rear, 6" skyjacker lift, 35" Toyo's, 15" rims, spintech exhaust
Here is what it looked like when i started. I dont have any pictures with the stock rims, but this is close enough
CopyKat
8
Manitoba, Coldest place in Canada
4.0L
Have you got a front view with the wheels straight? want to know about how wide the front is.
So have you got everything sorted out with the D44? The D44HD shaft is working good?
Josh40601
OTOTM Winner
MTOTM Winner
Solid Axle Swap
12
San Diego
i used the ranger mounts that came with the class II skyjacker lift. This is the best picture i have of it with the wheels straight. I never finished it. I scrapped the TTB and it is in the shop right now getting 3-linked with 14" coilovers and D44HP up front
CopyKat
8
4.0L
Wanna sell the D44HD long shaft? I've been looking for one locally and there is Jack around here.
Josh40601
OTOTM Winner
MTOTM Winner
Solid Axle Swap
12
San Diego
its a Dana 44 TTB from a 93 Bronco. I will sell you the shaft if that is what your needing
CopyKat
8
4.0L
I know it's a D44 TTB. But IIRC you were the one that used a D44HD TTB shaft to make it work with the RBV pivot points. Correct?
If so then yes I would be interested in the D44HD TTB shaft. (passengerside inner, not the center joint parts.)
Maybe the lengthened steering adjusters too if you still have them.
Josh40601
OTOTM Winner
MTOTM Winner
Solid Axle Swap
12
San Diego
nope. Never got it finished. It was pretty much a lifted 2wd. Never hooked anything up. The axle i have is the stock axle.
TheBeast
South carolina
4.0
Nice truck man. I like it
Josh40601
OTOTM Winner
MTOTM Winner
Solid Axle Swap
12
San Diego
thanks brother
ozziemo27
June 2010 OTOTM Winner
OTOTM Winner
18
Michigan
4.0 & 2.3
Very cool, man! You don't see this swap very often! I bet its pretty tough!
Josh40601
OTOTM Winner
MTOTM Winner
Solid Axle Swap
12
San Diego
its a pain in the fawking as. I do not recomend this swap to ANYONE. The D35TTB is just as strong. The only thing that is better on this one is the brakes and hubs. Best thing to do is just take the brakes and hubs off the D44 and drill out the tapers on the 35 knuckle to fit it. Then use the outer axle shaft off the 44.
PlumCrazy
OTOTM Winner
Solid Axle Swap
RBV's on Boost
2014 Truck of The Year
168
Millersport, OH
Engine Type
V8
2WD / 4WD
Solid Axle Swap 4x4
Did you have coils mounted to the 44 beams in the stock location and leaned in to the stock Ranger coil buckets?
Josh40601
OTOTM Winner
MTOTM Winner
Solid Axle Swap
12
San Diego
no, i cut up an old CJ bumper and welded it to the frame then mounted the stock coil buckets to the "spacer". Check out page 2 on my 94 ranger car domain (the link in my signature)
4x4junkie
Forum Staff Member
583
So. Calif (SFV)
Bronco II
Engine Type
2.9 V6
2.9L V6
2WD / 4WD
35x12.50R15
You don't get the full width that way though (wasn't that the point of a swap like this?).
Also, you need a much longer drop pitman arm on it.
Looks good otherwise though.
Staff online
Today's birthdays
Shran
April Truck of The Month
