Buying a 5R55E to replace my crappy 4r55e...Good Idea?
Dweano
3
Saskatchewan!
4.0L
Hey guys I have a 96 with a 4R55E...and its crap. I drove it with 3.73s and heavy toyo open country's for over a year and as a result its pretty sloppy. It flares up between shifts and it just feels kinda weak, kinda like its slipping. I'm not a professional expert on trannys...so it may just be that my torque converter is shot (what are the symptoms of that?) but my tranny just seems to have seen better days. I have an opportunity to buy a tranny outta a 2007 4x4...should be a 5r55e right?...anyways this tranny has 55,000 kms and is only two years old...mine is way older with 190,000ish kms on it and it has seen better days. The 5R55E is stronger internally and I plan on having 35's and 4.56s for the rest of the trucks life so that would probably be a good idea. According to this thread it is possible and in fact not too hard:
<<<<<Link>>>>>
I can get the tranny for $350...think I should do it? Thanks
Also...if anyone has odne this swap and is knowledgeable...should I get the torque converter from the 5r55e or a new one from a 4r55e? Probably 5r55e eh? Also the engines must be both 4.0l correct? Even if I have a OHV and this truck would have a SOHC. Thanks!
97fordrunner
9
New Richmond, WI
4.0
Get a new 5r55e torque converter, and i'm not sure but you might run into computer issues. You might be able to get a '97 ecu from a truck that had a 5r55e but thing is i'm not sure if the new trans is gonna be programed the same.
Dweano
3
Saskatchewan!
4.0L
Where is a good place to get a new torque converter from? Which one should I get? Theres different stall speeds and such (what does that even mean? Educate a newb...) Thanks for the response tho, I believe that it will not affect the computer, if you read the link it seems to suggest that the computer will be fine
97fordrunner
9
New Richmond, WI
4.0
stall speed is the engine rpm that the torque converter engages. for performance applications you can get tc's that engage at 2000,2500,3000 pretty much anything you can think of. I'd just stay with a stock stall for the best daily driving performance and reliability. The only thing I am wondering is if the newer trucks use a Trans control module instead of or inline with the ECM.
Dweano
3
Saskatchewan!
4.0L
I'll probably stay stock. Is there anyway I can improve my economy with a torque converter? Like ones that are best for fuel economy? Just saying...if I am doing this I might as well get the best one for me haha
Staff online
Members online
Shran
April Truck of The Month
