Used 3” spindle lift for ‘03 3.0
FillMarr
Ford ranger xlt
Anyone got a spare of these?
Rangstang
Mesa, AZ
If it ain't broke, I can't fix it.
Do your research before buying a pair. I've currently got Chassis Tech 3" lift spindles. I'm not a big fan as the turning radius increased massively when I installed them. It's difficult to even maneuver in parking lots. I contacted Maxtrac to see if their spindles keep the factory radius without compromising caliper interference and they haven't yet responded. I think the cost for an average guy to ship these is going to be quite expensive, so you actually may be better off buying new. Just saying...
FillMarr
Ford ranger xlt
Hi Rangstang,
Thanks for the comment. I think I am going to end up going with WheelsNParts' 4" lift, with some shackles for $325-ish.
I understand most people having turning radius loss from spindle lifts actually. The solution has something to do with grinding down the steering bump and installing new steerings stops somewhere else. Did you try anything like that?
EDIT: Rangstang -- did you trim the lower control arm during your install? That is necessary step that is supposed to solve the steering issue.
Any other input is appreciated!
Phil
Link:
https://www.amazon.com/gp/product/B00BENOOA4/ref=ox_sc_sfl_title_8?ie=UTF8&psc=1&smid=A3GPQJ0T2YEO4R
Rangstang
Mesa, AZ
I have read about that, but I wasn't a big fan of it personally for safety reasons. Interestingly, there was no instructions that indicated this needed to be done. In addition, I contacted the manufacturer about the issue and the rep that responded told me that they had never heard of this issue. Yeah, right! I probably will do the grind, but will reinforce it if need be. Good luck with your purchase.
Rangstang
Mesa, AZ
I just checked out the link you posted. That's for coil spring suspension, not the torsion bar like I have. I had a pair of the same brand for my 1999 coil spring Ranger and I had no issues with turning radius or caliper interference. Worked like they were factory.
FillMarr
Ford ranger xlt
Update!
I installed a pair of factory spindles from Doetsch Tech. I choose doetsch because i wanted 3” (not 4”) and I didn’t want to pay for fabtech. They look awesome. Wheel bearing fit and everything. Will post pics later. Now to lift the rear a little more to even it out.
Cons: Turning radius has definitely been lost a bit, but not to the bothering extent I expected.
The unexpected thing i don’t like is the feeling of lacking a factory steering stop. I don’t lose brakes at full turn or anything, but the wheel kind of snaps back a few inches when I go full turn and let go. It’s just a weird feeling. It’s probably the new spindle pressing against the lip of the side of the control arm. If anyone has tips on a new steering stop solution let me know.
As for grinding, looking at the control arm now I am not confident i really needed to do any. Really it only seems like a notch could have been cut out directly below where the steering stops are to allow the spindle to go full turn without hitting the control arm lip. That said, I left that alone. I didn’t want to put a notch there because it looks to be a critical spot to not sacrifice the structural support of the lip.
Also, the doetsch tech spindles come with hardware, but other than the bolts it is pure cheap garbage. That and I couldn’t put my dust shields back on!
Kirby N.
March Truck of The Month
