Serving Ford Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Forums Info - Technical Info - Other TRS News Photo Galleries Shirts & Decals Parts Store Classifieds
Go Back   The Ranger Station Forums > Engine & Transmission Forums > 4-bangers > 4-Cylinder (2000 & Older)
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 06-13-2012, 09:14 AM   #1
edman1000
Junior Member
Year: 1996
Make: Ford
Model: Ranger
Engine: 2.3L
Class: 4x4
Used For: Beatin on!
edman1000 is on a distinguished road
Default Breaking up over half throttle???
'96 4cyl, 5 spd
Ok, yesterday I drove to work and it was fine. nothing out of the ordinary. when I went to leave work I went to start it and I let off the key too soon before it caught. it kind of stumbled and sputtered a bit and then stalled out. I then restarted it, it cranked for a bit to get it going (like 5 seconds) then it fired up. When I went to take off I put the pedal down a bit, it was fine then I pressed it more (over half way) and it was sputtering and breaking up real bad?
I have done that before where I accidently let off the key too soon and it'll sputter out like that. but then it'll restart al ittle hard but then is fine.
what do you guys think? Throttle positon sensor? fuel filter? stress?
edman1000 is offline   Reply With Quote
Old 06-13-2012, 05:59 PM   #2
edman1000
Junior Member
Year: 1996
Make: Ford
Model: Ranger
Engine: 2.3L
Class: 4x4
Default
anybody?
Old 06-13-2012, 07:30 PM   #3
Earl43P
Premium Member
Year: 2000
Make: Ford
Model: Ranger
Engine: 3.0
Class: 4WD
Used For: DD
Earl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really nice
Default
For reliable starts, turn the key to Run, wait 3 sec for the fuel pump to "prime", then turn key Off.
Repeat, then crank the starter.
Make that a habit.
If it fixes it, your fuel pump checkvalve may be leaking.
If the fuel filter is old, replacing it may help.
__________________
If at first, you don't succeed, RTFM.
Earl43P is online now   Reply With Quote
Old 06-14-2012, 04:42 PM   #4
modelageek
modelageek's Avatar
Year: 1999
Make: Ford
Model: Regular Cab, Styleside, M5OD, 3.73 open 7.5 axle, RABS, 139k(3/08/2012), no A/C,
Engine: 2.5(5w30)
Class: 2WD
Used For: As a Turd Vehicle
modelageek will become famous soon enough
Default
Make that a habit.
I agree sounds fuel related. change the fuel filter and drop a bottle of techron in the tank........if that does not take care of it...........then do some fuel pressure tests....oh and clean the MAF and make sure the air filter is clean and the air intake tube is clear.........everything I just listed is maintenance anyways
modelageek is online now   Reply With Quote
Old 06-16-2012, 12:23 PM   #5
edman1000
Junior Member
Year: 1996
Make: Ford
Model: Ranger
Engine: 2.3L
Class: 4x4
Default
Clean air filter, clear intake tube
New fuel filter, New coil packs
I do smell gas so I know it's getting fuel. Seemed like it isnt burning it.
How Do i go about cleaning the MAF??
Old 06-18-2012, 10:08 AM   #6
edman1000
Junior Member
Year: 1996
Make: Ford
Model: Ranger
Engine: 2.3L
Class: 4x4
Default
I shot some Carb cleaner into the intake tube on the MAF and it helped. Now a day later it's doing it again. Do it need to replace it or just clean it better?
Old 06-18-2012, 10:38 AM   #7
modelageek
modelageek's Avatar
Year: 1999
Make: Ford
Engine: 2.5(5w30)
Class: 2WD
Default
Quote:
I am not sure why. maybe i am getting grumpy as i get older, maybe I am just tired of helping people. I am not sure why.......but I only help people that have created a detailed signature of their vehicle..
Old 06-18-2012, 04:25 PM   #8
edman1000
Junior Member
Year: 1996
Make: Ford
Model: Ranger
Engine: 2.3L
Class: 4x4
Default
Quote:
Huge oversight on my part, Thanks for being a grumpy ass and setting me straight!
Don't know why, I thought I did create one before. I too hate that. On the Foureyedpride mustang sight I see it all the time. It wastes a ton of time when you have to ask too!
__________________
'96 XL 4x4
2.3L 5spd
3" lift - Fullsize Bronco springs
Old 06-18-2012, 04:34 PM   #9
modelageek
modelageek's Avatar
Year: 1999
Make: Ford
Engine: 2.5(5w30)
Class: 2WD
Default
http://www.therangerstation.com/tech.../CleanMAF.html
check for codes even pending codes. catching a pending code is a good way to solve many issues.............if the MAF cleaning does not do it you might want to do a series of fuel pressure tests........they are pretty easy
Old 06-21-2012, 10:39 PM   #10
edman1000
Junior Member
Year: 1996
Make: Ford
Model: Ranger
Engine: 2.3L
Class: 4x4
Default
So when I spray the MAF it runs great until I shut it off an let it sit for a bit. Does this mean the MAF is shot? Should I find a replacement?
Oh, Also ruled out bad gas, Ran it pretty much dry and filled back up with 91
__________________
'96 XL 4x4
2.3L 5spd
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
