Bronco II quick mods
1984broncoduce
olive branch mississippi
ford
2.8
i was wondering if anyone had quick or cheep mods for guys to do t their b2s:icon_welder:
birddog321
18
Buford, GA
2.9
Shackles in the rear, Washer coil spacers in the front. Around $60 for parts and half a day of work.
azbronco2
Payson Arizona
2.9L
like he said and weld the spiders
4.0B2
TRS Banner 2012-2015
151
Walls, MS
4.0 v6
4.0 swap....
oh, seriously.. junkyard hunt my friend! buckets and center console or explorer dome light w/ 2 map lights on it, anything like that
if you can weld, have a scrap laying around-- sliders, steps, bumpers
throttle cable n zip tie mod
wash it!
body lift (i did my body lift for $30, used some freight liner aluminum gas tank spacer blocks(work part time at a semi shop)- all i bought was bolts)
headliner replacement (most need it since they are 20ish years old)
my paint was free-- again, work part time in a shop.
convert to manual hubs, again, junkyard hunt
there's a lot of things you can do cheaply if you look around, and wait it out.. i have $200 in a full parts donor rig (that might get built later in my life, its a 92 explorer that's gutted, but hey-- sas it, 5.0, so on)
Flat Toy
13
Dallas
2.9/2.5
Third brake light
Explorer Wheels
Explorer hatch handle
Shoulder harness for rear seats
Other then the wheels and tires nothing over $20.00. Aluminum wheels and tires $33.00 each, steel wheels and tires $17.00 each.
89Dog
Dana 35 for the front
4.0 Radiator
Flat Toy - I see the shoulder harness for the kids in back seat. I sent you a PM. Wondering how you did this one.
4.0B2
151
Walls, MS
4.0 v6
yeah i think we need a write up on that flat toy. i'm sure its probably fairly straight forward
1984broncoduce
ford
2.8
is the 4.0 radiator a strait bolt in mod? because i have one i just need to make sure i have everything before i start the swap
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Should be. It is on a gen 2.
Jorley
2
Crawfordville,Fla.
2.8 duraspark
Duraspark!
Best thing i have done to mine. Gets rid of computer, feedback carb and all those underhood wires. Only have 6 wires running to engine, 3 to alt and 3 to dizzy. I used the TFI coil. :icon_thumby:
http://www.therangerstation.com/tech_library/2_8Duraspark.html
mechanical temp gauge and oil pressure gauge
Cowl induction. Just need some dryer vent hose and duct tape. There is an inspection plate where hose goes into firewall, just remove it and put hose in it.
Twister
17
Omaha, Ne
Duh
5.0L, 2.9L
birddog321
18
Buford, GA
2.9
The 84 brackets don't fit perfect but they hold the rad in place. I almost rolled my 84 last weekend and it hasn't moved at all. Oh ya, removable doors are cheap and awesome:D
RICO9
07/2014 OTOTM Winner
OTOTM Winner
35
SL,UT
Title says 84.
Furd
2.8L w/ Chevy TBI.
People say that the 4L rad is not a drop in for the 84, I think you have to make brackets.
Yep. you need to make custom brackets. It's pretty easy though. I don't have a pic of the brackets I made, but here's a pic of the radiator in my 84.
Explorer springs will give a stock b2 a slight lift 1"-2" depending on how worn out the springs are.
Staff online
Members online
Shran
April Truck of The Month
