Battery light came on in instrument cluster
Iceman203
My battery light came on intermittently on my instrument cluster, then it stayed on while I was driving. It reset my radio presets but the truck never shut off. When I shut the truck off and turned it back on the light was off. That happened about two weeks ago and I've had no other occurances. Twice before my radio presets were reset when I got in my truck to crank it. I know whenever the battery light comes on everyone assumes the alternator, but what about the regulator? I heard they go bad sometimes. Any other reasons it would come on? A loose ground maybe? Is there a way I can test it to trace the problem? Thanks
mattpresley
13
Mesa, AZ
FORD F-250
6.2
Solid Axle Swap 4x4
Your voltage regulator is internal in alternator so, if it's bad just swap alt.
Iceman203
Is there anyway to test the alternator before I pull it off? Could it be anything else with the battery light intermittently coming on?
Spott
21
SE Idaho
Auto parts stores can test your alternator. A bad battery may trigger the light, but you wouldn't be able to start the truck. Wiring or connector problems between the alternator and the gauges may also cause the light to come on.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
A bad battery will not trigger the light.
The alternator will.
Earl43P
38
Farmington, Pa
Ford F250 4WD
