ranger 4x4 camber off now with 2 inch level kit
Danny505
Albuquerque, NM
3.0 v6
so my issue is my camber is off after i installed my 2 inch level kit spacers in my 95 ranger xl 3.0 4x4 what do i need to buy to fix my issue of what do i adjust
Danny505
Albuquerque, NM
3.0 v6
i have positive camber
Get the 3 degree bushing, put it in, and then take it down and have it aligned. The degree number is the highest it will produce, but those are adjustable, so they will give you different camber settings depending on the direction that they are installed. They can then be spun in the bore to make fine adjustment.
TrexMex
6
I got the alignment bushings from NAPA, they take a little bit of understanding for an alignment tech to get (they usually want the computer to do all the work for them and just spin the damn thing), but if you manage to get the technician to read the enclosed instructions you are on your way
Danny505
Albuquerque, NM
3.0 v6
Thanks i was gonna check with napa ill call today and stop on my way home from work.
bigmark303
RI
4.0, 2.5
Moog #K80109. 0-4 degree adjustable. Used those on two trucks I did the 2" level kit on. They come with a chart so depending on your knowledge and confidence level you can actually align the truck pretty easily yourself. The bushings do both caster and camber so you just have to adjust the toe seperatly by adjusting tie rods.
Danny505
Albuquerque, NM
3.0 v6
found it thanks its on page 2
87Ranger916
1987 ranger xlt 2.9 rwd camber issues after 2 in leveling kit
So I lifted my ranger with coil spacers and have come accros some major camber issues. Passenger side at 4.4 positive camber and driver at 3.3 positive camber. I’ve been looking for camber/ caster kits to remedy the issue but it seems that there are only up to +\-3 camber bushings made for the 87 ranger. Does anyone know some alternative solutions for getting the vehicle closest to no camber?
BlackBII
Ranger Custom
Truck of Month
982
UT
You can drop the axle beam pivot locations with some longer axle pivot brakets, you can cut and turn the axle beams, and you can also cut the lower balljoint mount and move it outwards. You'll also want to drop your radius arms to get a better caster angle and you may also want to check the angle on your steering.
