jonnygorman
- May 27, 2008
- Reaction score
- 0
- Age
- 42
- Make / Model
- Ford
- Automatic
Starter is locking out on my 85' bronco II. Starter has been changed out twice, thinking the bendix was the problem. The ring gear looks great. I thought I might have had the flywheel on backwards,as the exposed side of the ring gear has no bevel, as it turns out, either does the other side. All I can think of is that the fly wheel is bent or there is an imperfection in the ring gear that isn't visible while installed . Any experiences or suggestions out there? Just to make sure I have the flywheel on correctly, what should I see through the inspection plate? For a visual, the flywheel is beveled somewhat like a bell, with the top of the bell fastened to the flywheel. I am thinking it might be hard to put it on incorrectly, but it was so long ago I can't remember the details of installation.
Thanks
JOn
Thanks
JOn
