98 4x4 Dana 35
Ranger4x4newb
So I have a 98 4x4 and I'm curious if there are any better front differentials that are a drop in or close to it replacement. By drop in I mean I'm not looking to replace the transfer case to put something else in, mainly change the hubs, axles and diff.
SenorNoob
562
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
I've heard there is a front 8.8 in that configuration. Maybe look into that?
don4331
1,346
Calgary, AB
5.3
Replacing the front hubs/axles with '00+ gets rid of the vacuum hubs which is a definite step up.
8.8 from F-150 is next step up if wanting to keep SLA, but it is probably more work than solid axle swap...
Transfer case isn't necessarily swapped in a solid axle upgrade...
willy
cedar lake, in
5.0 explorer
If you want to keep ifs than 2000 ranger parts are your best bet all bolt on or join the sas club
85_Ranger4x4
17,814
SW Iowa
I would venture to say the front 8.8 would be a TON more work than a SAS... which isn't really a cakewalk the first time through either.
pjtoledo
2,963
Toledo Ohio
Fords
3.0 2.3
or 2004 knuckles if you want 12" rotors. but that means 16" wheels are necessary.
