what lift??????
1986b2
ford
what kind of lift do i need to clear 31-10.50-15's on my 86 b2? i want the smallest lift possible for that size tire..(i just like the look of big tires with small lift)..also my wheels are 15x10 ...and its going to used offroad
88_Eddie
Solid Axle Swap
155
Raleigh, NC
2.9L, 4.0L
smallest lift possible? some guys on here will prob tell you they've run 31's with no lift and just a little fender cutting. you could do a 3" body lift and clear them or get some coil spacers and some 2 inch blocks and clear 31's too. easiest/cheapest would be goin the body lift route
1986b2
ford
would 1" blocks and 1" coil spacers do the trick?
The Jester Race
OTOTM Winner
Solid Axle Swap
TRS Banner 2012-2015
68
Sacramento, Kalifornia
Ford, BMW
2.9, 4.0
It might, it depends on how bad your springs are sagged.
Here is mine with 2" block/spacer on 31"s
-Jester
1986b2
ford
how wide are you rims and what offset? and it looks like yours has room to spare
1986b2
ford
also did your front end align without aftermarket parts?
The_Dealer
10
Macon, GA
Duh!
i'd go with a duff 3" or skyjacker 4". good quality, good ride, heavy duty parts
1986b2
ford
i only want 1-2"s
The_Dealer
10
Macon, GA
Duh!
buy the 2" leveling coils in the for sale section, buy some camber bushings, buy some shackles or aal's and trim a little fender and u will be good
1986b2
ford
how far can i lift without buying camber bushings
The Jester Race
OTOTM Winner
Solid Axle Swap
68
Ford, BMW
2.9, 4.0
Oh hell I dont remember, they were stock 15"ranger wheels. Negative on the alignment, I was maxed out on the "extra" camber bushings and still had bad camber.
You can get maybe an inch of lift without needing the camber bushings. Remember as the TTB suspension cycles the camber changes ALOT. Welcome to the world of TTB's. I was broke, the tires were free, and a SAS was in my near future. So I didn't care too much, I ran it like that for little more then a year before my SAS.
-Jester
1986b2
ford
do you know the cheapest camber bushings that will work?
chrwilkins30
6
Mishawaka, Indiana
2.9
i got mine for about 75 bucks at napa. they are 3 1/4 degree. This will guarantee that it will get aligned. (unless you have suspension issues) Plus if you do go bigger later on you will already have high enough bushings.
1986b2
ford
Members online
Shran
April Truck of The Month
