EX dash gauge for battery issue
tjs4x4
2
ID
4.0L
I've had this problem for quite some time now. I thought I had it figured out when I realized my wiring harness for the left side of the cluster was backwards, but its not the entire case.
Every time I push the power window switches, it does not matter which one, the battery gauge goes up and down, indicating to mean a drain.
Took it to Oreilly's and the guy said the alternator and regulator are working fine, but that something is draining the battery, and THAT is why my HEADLIGHTS and all other lights dim when I hit the power window switches.
NOW, I have to know WHY this is happening. Has anyone had this happen to them? I replaced the driver's main PW switch thinking that was it, but its not. It's happening to all 4 switches. Any ideas where I can look for the problem?
tjs4x4
2
ID
4.0L
Anyone????!!!!
Shran
Junk Collector
Solid Axle Swap
Truck of Month
4,797
Rapid City SD
Engine Type
V8
5.0
I'd get a wiring diagram and find where the ground(s) are at for the power windows. Clean those up and see if that helps.
Sasquatch_Ryda
Ford Technician
OTOTM Winner
Solid Axle Swap
Forum Staff - Retired
TRS Banner 2012-2015
108
Terrace, BC, Canada
Engine Type
4.0L
2WD / 4WD
Solid Axle Swap 4x4
40s
Def sounds like a ground issue to me as well. My 91 does that a bit to, but only if you hold the power window switch in the up position when the window is already up....but not enough that it is really noticeable.
jovibuilt
9
Spruce Pine North Carolina
ford
4.0
How much does the gauge move?Its normal for it to move some.I have four explores and all of them do it.The gauge moves a little everytime you roll the window up or down.Power window motors draw quite a lot of power.
tjs4x4
2
ID
4.0L
It only does it a little, just worries me, but the fact that my HEADLIGHTS and all my lights DIM when I do this has me concerned, and the fact that the Oreilly's guy who tested my battery said there's a draw somewhere on it. The alternator tested fine, the regulator tested fine...but the battery is not. And that's my 3rd battery.
I SUCK at wiring diagrams. If anyone has one and can explain it to me, I'd be greatly appreciative.
4.0B2
151
Walls, MS
4.0 v6
Is it constant when moving the windows or just when it gets all the way up or down? My lights dim when the window is at the extreme point of up or down.
tjs4x4
2
ID
4.0L
It only happens when I use the power windows...
4.0B2
151
Walls, MS
4.0 v6
So the whole time you are pushing the button the lights dim? Okay, hmm clean grounds. Is the alternator putting out to it's full capacity?
Shran
Junk Collector
Solid Axle Swap
Truck of Month
4,797
Rapid City SD
Engine Type
V8
5.0
Find your power window switches in a wiring diagram for your vehicle. Haynes or Chilton might contain one. Next:
You are looking for this symbol...
This indicates a ground. Follow the line it is attached to until you find one or two letters next to it, these indicate the color of the wire. There should be a wire color code somewhere in the diagram too that explains what abbreviation is for certain colors. Now just find that wire in your vehicle and trace it back to where it is grounded at.
Sorry for the gigantic pic.
4.0B2
151
Walls, MS
4.0 v6
I still say it's a ground issue to. Clean every ground. Not only the ones by the switches.
tjs4x4
2
ID
4.0L
Yes it happens the whole time I'm pressing the buttons.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Well if you have a draw, you need to find that.
Hook up an amp meter to the positive cable, and the positive terminal with the cable unhooked, wait 20 minutes, then start pulling fuses until the draw drops off.
84bluebronco2
13
Central New York
4.0
My 94 Explorer's battery gauge moves when I use my power windows, but immediately spikes back up when I stop. Never seems to hurt anything for me. Just keep an eye on it Mach, and clean up the grounds.
Shran
Junk Collector
Solid Axle Swap
Truck of Month
4,797
Rapid City SD
Engine Type
V8
5.0
FWIW, I have two 500w amps in my F150 as well as a 10" sub... if I turn the volume up fairly high my battery gauge goes nuts. I wouldn't worry about this a whole lot.
Members online
No members online now.
Shran
April Truck of The Month
