Manual swap into 2002 sport trac
RangerRoad91
Florida
3.0 V6
Gonna be doing a manual swap in my bro in laws sport trac. The donor vehicle is gonna be a 1997 explorer sport 4.0 OHV. What all do I need to know about taking in this project? Can the m5od out of this work? Also can the ECM be used. I really appreciate any help. Thank you. If you need any more info I will give it.
4x4junkie
Forum Staff Member
583
So. Calif (SFV)
Bronco II
Engine Type
2.9 V6
2.9L V6
2WD / 4WD
35x12.50R15
There will be a slight difference in the location of one of the bellhousing bolts between the two engines (SOHC vs. OHV), but generally shouldn't be an issue if it's not in place.
Pedals and that stuff I believe are the same for both.
I highly doubt you can use an OHV computer on a SOHC engine, but I've not researched it.
Hope that helps.
swynx
9
lewiston idaho
Mazda
4.0
Hope that helps.
lots of people have used the ohv computer on the sohc engine, it gives it a lower redline.
4x4junkie
Forum Staff Member
583
So. Calif (SFV)
Bronco II
Engine Type
2.9 V6
2.9L V6
2WD / 4WD
35x12.50R15
Learn something new every day lol... I would've thought the engines being so different would've precluded it's use (or that if it did run, it'd be trouble-code-city).
There may still be some issues with it though in a state that has emissions testing (I know in Ca. a vehicle has to have the same model-year or later engine and emissions management for any kind of swap to be smog-legal).
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
TRS Banner 2012-2015
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
You will have a lot of issues running the ecu. Yes, it will run the motor, but you will have pats to deal with, the trac has pats E, the explorer type B. Type B can be wired in fairly easy, but you will need yo change the ignition cylinder out, and thats providing you have the keys to the ex. Pedal assembly will be the same. Your best bet would be yo swap in the OHV engine as well, since the SOHC engine has the timing chain issue, or I'd highly suggest doing the timing chain cassette upgrade while swapping the trans...
SVT
Staff online
Members online
Shran
April Truck of The Month
