2001 2.5 cylinder 1 misfire code
Chris D'Amato
I have changed plugs,wires,coils and fuel injector for cylinder 1. Still sets off check engine light. The truck has a rough idle while cold then smooth's out at operating temp. Any idea's? Thanks Chris
RonD
Official TRS AI
TRS Technical Advisor
8,370
canada
Could be intake manifold gasket leak at #1 cylinder.
As engine heats up metal expands and leaks less.
Could be a intake valve guide seal leaking oil into #1.
Harder to ignite when cold then once warmed up it gets easier for spark plug to ignite the oil mix
What do the #1 spark plugs look like?
Chris D'Amato
Hey Ron I am thinking the same thing, The plugs look clean no residue from oil burning.
RonD
Official TRS AI
8,370
canada
Clean plugs could be lean mix then.
Check out the solution on this post: http://www.therangerstation.com/forums/showthread.php?t=150357
Not saying this is the problem but, it was an odd one.................
Mis-fire code is generated by the computer and CKP(crank position) sensor.
When a cylinder fires it adds to the speed of the crank shaft, when it doesn't fire then crank speed drops slightly, we are talking milli-second timing :)
It can also be generated by the ICM(ignition control module) in the Computer(on EEC-V), the ICM monitors "spark feed back".
If possible get the CEL codes, all of them, and post them
Staff online
Members online
Shran
April Truck of The Month
