alternator swap question
pontiacfieroguy
12
oak ridge,tn
1989, rip1988
ford
2.3 4cyl, rip 2.9v6
I saw on this thread http://www.therangerstation.com/tech_library/130_amp_alternator_upgrade.shtml that i can put a 130 amp alt on my 86 bII 2.9 if i cut the white wire on the plug but i don't have a white wire, i have one plug with 2 black wiress and one plug with a yellow wire and a green wire side by side and a rubber nub where a wire could have gone and an opening on the plug portion. in the diagram on the thread it shows the yellow and green wires on opposite sides of the plug and the white in the middle.
can i modify my plug to make a 130amp alt work or should i just buy a factory replacement 65amp alt? I don't have time for trial and error because i start my new job repoing cars tommorow afternoon and i can't call in my first day.
RonD
Official TRS AI
TRS Technical Advisor
8,370
canada
If you buy a 3G alternator then just wire it up as shown in diagram.
Your two Black wires sound like the B+ wires that go to the battery(starter relay post), so can be reused, but if you add more power draws to the vehicle you will want to change to a larger wire and fuse for those.
The Green wire in the diagram turns the alternator ON and OFF with the Key.
So unplug your connector and test which wire(yellow or green) ONLY has 12volts with key ON, and has NO volts with key off, should be YOUR green wire but if not which ever one it is will be the Green wire in the diagram.
Yes you may need to buy a connector for the 3G alternator, or get one at a wrecking yard, that has the Gray jumper wire
Andy D
10
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
KISS, replace the alternator with the same for now. Buy the 130 amp after a few pay checks. :D
pontiacfieroguy
12
oak ridge,tn
1989, rip1988
ford
2.3 4cyl, rip 2.9v6
I don't know why i didn't think to get the plug off the donor, been a long day between court and two interviews i guess.
Staff online
Members online
Today's birthdays
Shran
April Truck of The Month
