what part years fit what
Troll
ford
Hi, sorry but this has been asked 100 times. I just got a 1990 ranger and I am wondering what year(s) can I use parts from to fix it up..... thanks
gribly
28
Maine
Honda
K20A3
Err, could you be a little bit more vague? What parts? What truck do you even have? What is wrong with it?
Troll
ford
sorry, body parts.... the drive train is good enough , for now.... It's a 1990 extended cab 4x4
RangerBoy94
24
Northern California
360CDI
83-92. Every body panel will work except the grille but fenders, cab, doors, bed will all work.
Sasquatch_Ryda
Ford Technician
OTOTM Winner
Solid Axle Swap
Forum Staff - Retired
TRS Banner 2012-2015
108
Terrace, BC, Canada
Engine Type
4.0L
2WD / 4WD
Solid Axle Swap 4x4
40s
89-92 is what you will be looking for
Insanejughead
RBV's on Boost
33
Missouri
'94, '86
2.3T
Here's some broad answers to your vague question about parts.
Exterior: 89-92 (except where RangerBoy pointed out.)
Interior: 89-94
Suspension: 83-97 (The exception being the beams and spindles because of the ball joints. I don't know if the 4wds differ at all between D28 and D35 at the ball joints.)
Brakes: 83-94 (Though, 95-97 had a dual piston caliper that will work as long as you swap the brake line with it.)
Engine/Transmission: Any year that has your same engine will work (Except distributor parts, and if you have a 4.0 it also depends on if you have a OHC or OHV.) ***Double check journal/bearing/gasket part numbers and sizes before taking my word for it***
After all that, you're pretty much left with the piddly stuff that holds the ranger together: like bulbs, bolts, accessories, and wires.
scotts90ranger
RBV's on Boost
4,367
Dayton Oregon
Engine Type
2.3 (4 Cylinder)
2.3 Turbo
2WD / 4WD
35"
with the '89 body change, the hood, fenders, headlights and grill all changed but the doors and bed are the same as '83-88
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,821
SW Iowa
Engine Type
V8
5.0
[Brakes: 83-94 (Though, 95-97 had a dual piston caliper that will work as long as you swap the brake line with it.)
You have to get the spindle to go with the bolt on caliper, they don't use wedge slide pins like the older trucks.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I think this guy might be a Troll.
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
Work hard and play harder
Does he have flowing green hair?
Insanejughead
RBV's on Boost
33
Missouri
'94, '86
2.3T
No, but he does live near a bridge.
Oh, and 85Ranger, I knew I had left something out of that thing I said about brakes when I wrote it. Thanks for filling in the blank.
racsan
4,441
central ohio
ford/escape
Engine Type
2.5 (4 Cylinder)
2.5/151 I-4
2WD / 4WD
2WD
the grey-t escape
i live near a bridge, maybe he's living under it. i'll go check in the morning.
Troll
ford
Thanks for all the info, :beer:
Members online
Shran
April Truck of The Month
