post your topless bronco.
jarfly
Post some pics and info on you ride. Lookin for some ideals on this.
Broncotim
Tennessee
2.9L
Here ya go. The red Bronco is my 1988 that I have owned for 15 years. The black Bronco II was a 1984 2.8L Duraspark conversion with a chopped top. I recently sold this Bronco II.
JaKaL3483
Vancouver WA
bronco 2
2.8 for now
mine is the one on the left, cut the top off at the front of the windows and bottom corners, took the hatch off. cut the rear pillers off just leaving a sheat of metal for later use. moved the rear pillers up to the existiong cab and welded togeather, then re mounted the rear hatch after some trimming, bolted down with angle iron and a little welding, then filled the gaps with great stuff foam sealer, then long strand fiberglass. and the rest is history, but if you need to know anything let me know. I just moved up my wheel wells too, but i havent taken pics yet. will show them to you when i get them done all the way. :icon_cheers:
hopster
9
Bedford, IN
2.9, 4.0, 5.0 can't decide
I recently flipped this truck, I had a roll bar in the back but the cab got crushed pretty bad so if you do this add some roll protection in the front too. this is the only picture I had with the top on it. I made it out of a boat cover and some cheap buttons.
1badexplorer
Firefighter
4
Sutersville Pa
3.0, 501, 7.3psd, 351c, 351w
Here's mine. I also cut off the rockers, and trimmed the fenders. Those are 31/13.50 swampers with no lift :headbang:
89bII
how did u get them tires on there with no lift do they rub bad
brown bomber
nice i got 30x9.5 with a 2 inch lift and i had to roll my fenders and they still rub bad
