Cost of new exhaust?
tidmarshsmiths5
South Carolina
2.8l stock
Alright, I've had enough of my rumble trap exhaust and all the noise it makes...plus it's got more holes in it than a politician's promise...
Anyway, from the Y back the guy told me all new (higher flow Cat), he'd charge me $325...just seems high to me...I was thinking probably $200 mark.
Either way, I'm going to get it done (this guy is honest) and he said I would notice a difference in the way the truck (horsepower) ran but I don't hold a lot of stock in that (he wasn't selling, just stating). So, I should have the power of a 5.0 under there when he gets through - ha!
Fair price?
kimcrwbr1
46
maplevalley WA
2.8l
That sounds like a fair price especially if they bend up a new tailpipe. My muffeler guy only replaces what is necessary. Have you done anything to the motor is it still running on the computer? What happens to the older 2.8s is the valve guide seals disintegrate. If the engine blows black smoke at startup replace the valve guide seals the oil will destroy the new cat rater quickly. You can replace the seals without removing the heads using air pressure to hold the valves up. Then adjust the valve lash.
http://www.therangerstation.com/tech_library/2_8L_Performance.html
tidmarshsmiths5
South Carolina
2.8l stock
Have done nothing to the motor...still on the old computer...do get some smoke at startup but the thing leaks like a sif...needs valve cover gaskets in the least and I'm pretty sure front and back main seals...just hate to have it rebuilt when it runs so decent right now (not perfect but she runs pretty darn good)...22-23 mpg...
$1500 to rebuild
$250 - 400 to replace valve cover seals (so why do it until rebuild)
main seals - why bother unless I have a new clutch to put in (hey, it's all out might be the perfect time) so I keep waiting for it to break and then I'll have it rebuilt and put a 4.0 clutch on it if I keep the 2.8...
or get real brave and find a 4.0 donor; have it rebuilt and drop it in...I just don't know if I have the money, the time or the mechanical aptitude to do it...I want to duraspark it but I HATE wiring (it makes absolutely ZERO sense to me)...
If only I could win the lottery...anyway, perhaps I should just wait on the muffler until the rebuild???? And, that valve air thing sounds tricky...I'm not dumb, just mechanically inept and have to learn as I go and I am a SLOW learner...
ab_slack
12
New Joisey
2.9L
for all OEM fit parts from Y pipe back it is about $500 most of which is cat. Muffler and tailpipe were about $100. Now if you are going special custom, I know some CATs are pretty cheap <$100 so parts cost would be nearly $200. $400 seems somewhat reasonable. Less cat cost but more fit cost.
kimcrwbr1
46
maplevalley WA
2.8l
I think I paid $78 for the cat at autozone and my muffler guy charged me $40 to install it it took all of 15 minutes. I prefer the little Ma and Pop shops myself. Slap the muffeler with your hand if it is full of stuff it is likely catalist. Do you need to pass emissions if not pull the cat and rod it out. Install a new muffler and run it till it pukes.
Spede Demn
Irricana AB
'85
2.8L
Sounds like a very fair price to me, last one I had done was on a Ranger for about $410 I think it was, Ranger is longer and I wanted it very quiet so I think the muffler was expensive.
Hate wiring?? Thats the best reason TO DO the duraspark conversion, your throwing all the crap out and end up with less than a dozen wires under the hood, AND you end up with a noticable improvement in power and fuel mileage, still a 2.8 so its no race truck but it made a big differance on mine'
Just the valve cover gaskets are cheap and easy to do yourself, I did mine in about 6 beer, I mean hours... well both actually.. lol... and I adjusted the valve lash while I was at it, which is also something anyone can do easily that makes a big differance in power and mileage. Now that Ive done the duraspark I could probably do the gaskets and valve lash in less than 3 hours because theres no junk in the way.
IMO.. for anyone on a budget the 2.8 is great little engine, cheap and easy to maintain even if your still learning mechanics, and it will push a B2 with 30" tires thru pretty much anything.. get every mile out of it you can.
ClaytonBigsby
PNW
Turd.8
I paid $350 for a Dynomax hi flow cat/muff/pipe/tip. Sounds pretty fair to me. The shop that did mine has a great rep.
