2011 Ranger questions...
BRONCMAN
Hello.
I was looking at possibly purchasing a new ranger. I'm looking at a super cab 4x4 4.0. All I can find is 3.73 equipped trucks & I was hoping to find a 4.10 geared truck with a manual transmission as I do occasionally tow a 6x12 tandem axle enclosed trailer in the 3000 to 4000 lb range. I noticed Ford has higher towing capacities with the auto option, but I would think the m5od would be a stouter choice as long as you know how to use a clutch. What has me puzzled though is why Ford would rate the 3.55 equipped truck to tow 5800 with an auto & 3340 with the manual. Now with 3.73s or 4.10s it is rated LESS at 3100/ 5560. Why would they rate a taller geared truck to tow more as that much more stress would be placed on the drivetrain. I'm sure the 8.8 axle is plenty strong enough as these axles use to be uses in the 150s & broncos. Also to those that do tow, would you try to get them to find a 4.10 geared truck & do a dealer trade or something or just settle for 3.73s. Also is there much of a mpg difference unloaded with 3.73s vs 4.10s?
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
The hard parts of an auto trans are stronger than a manual because the gears are constant mesh and have more contact surface.
3hokies
Winchester, VA
2.9L
More than likely you won't find any Rangers in stock anywhere with anything but the 3.73 axle. Most dealers aren't going to order anything else. I've got 3 and the all have 3.73s.
grey
Hamilton, Ont
4.0
Gears in a syncro box are meshed all the time too ;)
The weak link in the manual tranny is probaby the clutch.... Slip too much, add more skinny pedal and wooooooooo! Magical black smelly smoke!
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,826
SW Iowa
Engine Type
V8
5.0
The Ranger has a mutant 8.8. It has a 8.8 ring and pinion but still has the same shafts and axle bearings as a 7.5.
It is hard to tell with the gearing thing, it could be tires or something too. Usually they play with tire sizes to come out with the same ratio in the end, 3.73 or 4.10 trucks have bigger tires than 3.55 trucks so they come out running the same rpm down the road. They might want a thinner more stable tire for towing heavier loads. :dntknw:
02RangerXLT
53
NE
4.0
The two ranger's I've owned (2000, and 2002) have both been stock with 4.10's...
Sasquatch_Ryda
Ford Technician
OTOTM Winner
Solid Axle Swap
Forum Staff - Retired
TRS Banner 2012-2015
108
Terrace, BC, Canada
Engine Type
4.0L
2WD / 4WD
Solid Axle Swap 4x4
40s
All the newer ones with the traction control and rear discs seem to all be 3.73 diffs in em.
I towed 5500 lbs 24 foot travel trailer with my 05 sport trac, 4.0L SOHC and 5R55E auto trans with 4.10's and it was ok.
Will
Forum Staff Member
514
Gnaw Bone, Indiana
Toyota
4.0
It's possible that I could learn to like you. Not likely, but possible.
An auto is fantastically stronger than a manual. A C5, 50% lighter than a Ranger M50D 5-speed, can be built to live behind a 500hp 460. No part inside the C5 is too large to use for the FOB on a gas station bathroom key.
What adsm08 means is that internally, there are no load spikes like you see with a manual. It clicks from gear to gear smoothly with one thing releasing as the other engages. They have the timing down pat. On some early autos--late 40s, early 50s, there was a hydraulic coupler behind the torque converter. They would empty the fluid out of the coupler, change the gear, then fill the coupler back up to reattach the engine. It's not necessary anymore because they have the timing sorted out so it's seamless and instant. The drawbacks of an auto have almost completely disappeared, which is why a manual is no longer offered in many vehicles. I think the auto in a late model Ranger is completely fixed as well. The torque converter is the only heat source in an auto that requires the cooler, and with the lock-up converter, you almost don't need a tranny cooler. Some early engines had a finned aluminum converter and no external cooler. The auto posts better EPA ratings in some applications and it could be very soon that the only reason you would have a manual shift around was for fun. it might be that way now.
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,826
SW Iowa
Engine Type
V8
5.0
Options have been falling left and right as the Ranger nears the end of production.
Dealers don't really care about them so they don't get very creative about what they order either.
bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
it is easier to fix and understand than "her"
that reminds me of riding in some old gassers....big rush of long forgotten memories:icon_thumby:
BRONCMAN
Well, instead of buying a new ranger I found a complete powertrain out of an
06 to swap in. Its a 4.0 sohc, 5R55E transmission, transfer case, all accesories, wiring harness, & ECU. I even got the front driveshaft. Lol. I didn't want an auto, but couldn't pass it up. Looks like I have a spring project in order now. It should be a one of a kind truck when its all finished.
Will
Forum Staff Member
514
Gnaw Bone, Indiana
Toyota
4.0
I think that's a good setup. I wouldn't have any concerns about using an '06 auto.
BRONCMAN
Yeah, they definitely are a lot better than the old A4LD. I had a 98 with a 5R55 & it went 225k before being replaced. I just kind of liked shifting my own gears with this truck, but I'm sure ill get used to the auto.
Staff online
Shran
April Truck of The Month
