Sbc swap.what front and rear differential do I need
Robx92
I'm going to be swapping a 357 sbc in my 88 4x4 ranger what front and rear differential do you guys use
bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
TRS Banner 2012-2015
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
it is easier to fix and understand than "her"
under 350 hp?
the ranger d35 in sla or ttb and 8.8 out back with a full carrier locker with up to a 35 in tire work ok to pretty good with mild abuse.
over 350 hp and i would go to a ttb 44 or at least a worked straight axle 44 up front and a 60 out back if tires 35 or larger are on the agenda and 4x4 use is moderate. if heavy use is planned rcv axles for the ttb 44 or straight axle will put you near stock d60 territory but it will cost some big cash.
in your case, with a straight axle swap using a driver drop or passenger drop is up to you and what t case you want to use. actually in any case it is up to you what side you want the front pumpkin on....but with a chevy engine its just easier.
if i had a bored out 350 laying around....i would sell it and go with a ls platform...
Shran
April Truck of The Month
