doorgunner
Lab Rat for V.A. hospital
MTOTM Winner
2009 Truck of The Year
- Oct 22, 2008
- Reaction score
- 516
- Make / Model
- Ford Ranger
- Engine Type
- V8
- Engine Size
- 350+1
- Automatic
- 2WD / 4WD
- 2WD
- Total Lift
- N/A
- Total Drop
- 3/4
- Tire Size
- 23570R15
- My credo
- JESUS Loves Ya!
Combine the advice: buy a cheap vacuum gage & run the hose thru the firewall so you can watch the guage whle driving.
Drive along your usual route with your current drivetrain set-up & log the different vacuum readings at mile-markers along your route.
Swap out your present wheels with "taller wheels" & drive your route again--logging the new vacuum readings.
If the vacuum readings are lower on average with "taller tires---you're hurting your gas mlieage.
Once you have the "correct heigth" wheels installed and have driven on your test-route...the vacuum reading should be higher.
