1993 Ranger Splash. Will newer door panels interchange?
Kuneff
I have searvmched and googled and can not seem to find a straight answer. My driver door panel is in rough shape. I can't seem to find one that matches that's power. Does anyone know what years will bolt up and interchange? I am now starting to look for a newer set and replace both so they still match one another.
As for the switches as long and I can pull the pins on my plugs and them plg into newer end I can change the pin out to make newer style switches work. It can't be any harder than it was to add OEM power windows, locks, Cruise and AC to my truck. Provided door panels will bolt on.
Thank you in advance for the knowledge.
97RangerXLT
Forum Staff Member
3,937
Fishers, IN
Engine Type
4.0
2WD / 4WD
2"
31"
Should be bolt up no problems. 93-2012 should all interchange with some minor tweaks... worst case as you mentioned will be to rep in the wires to match, or swap the guts and door panels from your old door.
AJ
Sent from my Samsung Galaxy Note 4 while sitting in my underwear
Shran
Junk Collector
Solid Axle Swap
Truck of Month
4,796
Rapid City SD
Engine Type
V8
5.0
93 and 94 will for sure, I am almost certain that 95-97 will as well, and possibly newer than that. 92 and older won't work. 93 and 94 have a different style grab handle than the newer trucks so that's your best bet for exact match.
ericbphoto
Overlander in development
TRS Event Staff
GMRS Radio License
16,592
Wellford, SC
Engine Type
3.0 V6
3.0L
2WD / 4WD
6"
35"
In theory, theory and practice are the same. In practice, they are different.
Thanks for asking this question. I need the driver side panel for my '93 Splash, also and have been limiting my search to '93-'96 model years. I just look when I'm at the junk yard and not in too much of a hurry.
Staff online
Today's birthdays
Shran
April Truck of The Month
