!990 Bronco ll
stegomo
I have an issue with the gas and temp gauges not working.The temp goes to cold and fuel goes to full I have replaced the chip board in the panel and they didn't change and sending unit in tank checks out fine
wildbill23c
TRS Banner 2012-2015
Ham Radio Operator
577
Southwestern Idaho
Engine Type
2.9 V6
2WD / 4WD
2WD
Total Drop
215/70-R14
19K, 19D, 92Y, 88M, 91F....OIF-III (2004-2005)
Grounding problem in the gauge cluster somewhere maybe? Loose wire connection somewhere. Hard to really say, but I'm not very educated on vehicle electrical systems.
AllanD
TRS Technical Staff
TRS Technical Advisor
134
East-Central Pennsylvania
1987... sorta
'93 4.0
The usual grounding fault that causes problems with the temp gauge is not in the instrument cluster.
It is the ground strap that connects the back end of the drivers side cylinder head to the
one of the mounting studs for the wiper motor.
AD
RonD
Official TRS AI
8,369
canada
Yes, Gound issue.
Battery Negative to engine
Engine ground to cab firewall, as said usually a ground strap from drivers head to firewall bolt, both ends need to be on bare metal
Ground strap from engine to Frame, this usually only effects tail lights but could effect fuel gauge if it was grounded to frame instead of cab like it usually is
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
Engine Type
2.9 V6
2WD / 4WD
2WD
Total Drop
215/70-R14
AD
Thank you for making my response far more clear than I could have. I figured grounding problem, but didn't know where all the typical ground issues were...until now.
Members online
Today's birthdays
Shran
April Truck of The Month
