Serving Ford Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Forums Info - Technical Info - Other TRS News Photo Galleries Shirts & Decals Parts Store Classifieds
Go Back   The Ranger Station Forums > Engine & Transmission Forums > V6 Forums > 4.0 Liter Forum
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 08-22-2012, 09:23 AM   #1
XLTbeater
Junior Member
Year: 1991
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 2WD
Used For: schlepping
XLTbeater is on a distinguished road
Question E-Fan?
Hi guys! I have a Flex-a-Lite 2500cfm single electric fan (puller) from one of the past vehicles lying around. Do you think that is enough to cool a stock 4.0L? Or do you think I need a pusher fan in front of the A/C condenser as well as the puller mentioned? My plastic mechanical fan is cracked and whistling with a little RPM. It will probably last another 21 years, but I have this other fan available, so......
XLTbeater
XLTbeater is offline   Reply With Quote
Old 08-23-2012, 02:53 PM   #2
notaprob
Junior Member
Year: 1994
Make: Ford
Model: ranger xlt
Engine: 4.0
Used For: Daily Driver/Rowdy Times
notaprob is on a distinguished road
Default
I'm not saying that I would recommend my exact fan but I have a 14" electric fan that pushes or pulls 1,250 cfm (not including radiator and the ac). I live in 90+ degree weather most of the time and it stays around the "o" and "r" on the gauge inside of the truck even in heavy traffic, which is pretty good. However, I am going to change it out to get a bigger fan because it gets a little hot in low range 4x4. If I am creeping up a hill, it will eventually get to "L" on the gauge but nothing higher.
notaprob is offline   Reply With Quote
Old 08-23-2012, 04:56 PM   #3
--weezl--
June 2011 OTOTM Winner
--weezl--'s Avatar
Year: 2007
Make: Ford
Model: Ranger FX4 Level II
Engine: 4.0
Class: 4x4
Used For: stealing candy from babies, and sometimes driving to work
--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute
Default
if your fan will last another 21 years, i wouldn't bother replacing it, unless you want to...
2,500 sounds like enough to me... slap her on and see what happens...
__________________
Quote:
Originally Posted by Insanejughead View Post
Don't worry Weezl, if you're banned I'll petition to have you brought back.
Quote:
Originally Posted by multiranger View Post
I asked my girlfriend to measure it for me.. It's only an inch
check out my build thread
--weezl-- is offline   Reply With Quote
Old 08-23-2012, 08:44 PM   #4
bobbywalter
RBV Technical Advisor
bobbywalter's Avatar
Year: 1988
Make: FORD
Model: RANGERISH SORT OF THING
Engine: BIGGER
Class: 4X4
Used For: EVERTHING
bobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to behold
Default
i agree.
the stock cooling is real good. i prefer e fans but for stock use and applications i would not mess with it unless it was failing.
__________________
88 ranger ext cab low rider 4x4 propelled by 395 cubes of of non turbo SLOBBERIN DIESEL...BLAHHH...motating a 4l80 thats AUTHORITATIVELY turnin a ford 208 spinning 410 open dana 60s and whatever tire suits the mood that day. how ya like me now?
bobbywalter is offline   Reply With Quote
Old 08-24-2012, 12:12 PM   #5
XLTbeater
Junior Member
Year: 1991
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 2WD
Default
I have no idea how much longer the mechanical fan will last; I'm just guesstimating. It has a few cracks that span from the center, along the side, and to the tips of a few blades. Since all of my past vehicles had metal fans, I have never come across this problem. I might install the puller fan and see what I get. I will keep the mechanical fan just in case I need to switch back.
XLTbeater
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
