KDub57
- May 11, 2017
- Reaction score
- 0
- Location
- Titusville, FL
- Make / Model
- Ford
- Engine Size
- 2.9 EFI
- Automatic
Hi everybody. I’ve got a noise coming from my 89 Bronco II RWD automatic which I’m having trouble diagnosing and I’m looking for thoughts on the matter. This post is a bit lengthy, but I want to make sure I include all relevant information.
So here’s the problem: I’m getting a high-frequency, low-amplitude whirring noise coming from somewhere in the truck. I believe it’s the differential, but I’m not totally certain. The noise occurs from about 44mph on up and is loudest around 65mph. It happens under moderate acceleration, cruising, and floating (backing off the throttle to decelerate without engine braking), but it does NOT happen while coasting (decelerating without throttle), and I cannot hear it under heavy acceleration. The noise is definitely related to wheel speed and not engine speed, and what gear the transmission is in doesn’t seem to make a difference.
At the beginning of last summer I needed to make a trip from Daytona Beach to Cleveland for an internship. I ended up towing a 900lb trailer (my motorcycle) plus about 100-200lbs of cargo in the back of the truck. Along the way, whenever I would hit a dip in the road or reach the bottom of the hill, I’d feel a momentary “extra” vibration, almost like a grind. I figured this had to be because of all the extra weight on the rear end and immediately regretted starting this trip. But at the time I didn’t have any other choice but to keep going and eventually made it to Cleveland in one piece.
I first noticed the noise about a month or so after that during a time when the truck had not been doing any heavy lifting. I can’t recall any one particular moment when it started, nor a specific singular event that might’ve triggered it. At the end of the summer I needed to make the trip back down to Daytona, and in preparation for the trip I topped off the oil in the differential (it was about half a quart low) and I got some helper springs to handle the load better. No more instances of “extra” vibration on this trip. However, the Appalachian Mountains proved to be too much this time and my baby broke down coming out of Morgantown, WV. Ended up having the transmission rebuilt and the water pump replaced, but I eventually made it home.
Since then I haven’t been able to do anything about it. The noise has persisted, but at least has not gotten any worse. I’ve also got a “clunk” sounding off whenever switching from forward to reverse and vise versa, which I think is due to worn u-joints in the driveshaft. I’ve got those CV u-joints and I’m thinking about swapping the shaft out for this:
http://bit.ly/2pp0DZG
I currently have the diff opened up to change the fluid. I discovered the tiniest of cracks on the mating surface of the stock fiberglass cover and now I’m waiting on a new steel cover in the mail. That explains why the bottom of my diff always looked wet but there was never any oil on the ground beneath it.
Based on the conditions and symptoms I’m hoping someone here might have some insight into what may be causing my noisy woes. I can inspect the differential but I just don’t know what to look for. I’m thinking worn gears or bearings…I’m just not sure. Any help that can be offered is much appreciated. Thank you for reading.
