HELP! What spline axles do I have in my Ranger?
BarleyPop
Howdy guys,
I’m trying to find the axle spline count on my 2011 Ford Ranger, before I take it apart. S# 1FTKR1AD2BPA9XXXX
Axle code 96 so I know it’s a 3.73 open. It is an XLT 2 wd 2.3L 5 speed manual 112 wb. Only options, cruise and alloy wheels
But here is the strange part, the tag on the axle is S312D and not listed anywhere I can find. The tube ext dia is 3.25” with factory disk brakes.
So I’m thinking it should be a 31 spline? Maybe?
Just wanted to know before I order my new LSD to put in before another PA winter.
Thanks,
Barley Pop
BarleyPop
Follow up, if I need a 28 spline LS diff, Yukon or Auburn?
Howdy Gang,
Seems I may have 28 spline shafts so my LSD choice may change.
Hoping to be under $300 for the Ford T-L, but that may not happen.
Yukon and Auburn both offer LSDs for the 8.8 28. Any thoughts?
My jeep buddies like the Yukon and at just under $500 both seem close.
The Yukon looks easier to rebuild if needed. I'll call each sales dept and get a vibe.
Let you know.
Thanks,
BP
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I'll confirm it is a 38 spline. As has been stated countless times on this forum unless you have an FX4 Level 2 package truck,which were only made for a few years in the early 2000s you have a 28 spline axle.
BarleyPop
Thanks '08
Kinda what I thought. So, now what LSD to get?
90% street use, traction needed for rain/snow on roads to work.
10% movin' firewood for my father-in-law.
BP
pjtoledo
2,913
Toledo Ohio
Fords
3.0 2.3
Howdy guys,
Thanks,
Barley Pop
take that damn tag off, they hold moisture and the tube suffers from rust, LOTS of rust, under that tag.
Staff online
Members online
Today's birthdays
Kirby N.
March Truck of The Month
