Hybrid Dana 35
natmanjoh
Kent, WA
4.0l
I got a Dana 35 hybrid with 4.10 gears for free but it's just the pumpkin side. I have a rear 8.8 with 4.10 gears with a locker.
Should I just go to the junkyard and pick up the other side and throw the hybrid in or keep saving for a real Dana 35?
Is the hybrid an upgrade from my 4.10 Dana 28?
I run 31 in tires and don't plan to upgrade tires until I get a real Dana 35.
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
It's a minor upgrade from a D28 in that you'll have larger u-joints with the hybrid axle, but not too far behind that you still have the tiny 23-spline axles where it enters into the differential. With 31s and gentle wheeling it should hold up until you can get a D35 anyway.
I suspect once you do find a usable other half to go with your hybrid axle though, the opposite half that is an actual D35 will likely be attached to it (or at least sitting right there next to it), so it might be better just to grab the whole thing rather than just the one half. You could get lucky and the D35 has 4.10 gears in it too if it's from a '90-'92 4-cyl or 2.9L truck... But if not, you can also use the hybrid diff for it's 4.10 gears while you save up to get the real one regeared and maybe a locker added to it, then it's just a matter of swapping out the hybrid chunk (and two inner shafts) with the D35 chunk.
natmanjoh
Kent, WA
4.0l
Hey junkie thanks for the response. Will the ring gear and pinion fit in the 28 from the hybrid 35?
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
I THINK they will, but I can't say for absolute sure.
